Viscosity 5W-30 Oil - Is It Correct?
  • Thread starter Thread starter VooDoo
    Oil Viscosity
The discussion centers on the properties of 5W-30 synthetic oil, specifically its viscosity measurements. The dynamic viscosity is confirmed to be 20.0 x 10-3 Ns/m2, while kinematic viscosity values at 100°C and 40°C are provided as 10.3 cSt and 50.9 cSt, respectively. To convert kinematic viscosity to dynamic viscosity, the density of the oil (876 kg/m3) is used, yielding a dynamic viscosity of 9.02 x 10-3 Ns/m2 at 100°C. The actual viscosity can vary significantly with temperature, indicating that both 20E-3 and 200E-3 could be valid under different conditions.
  • Understanding of dynamic and kinematic viscosity
  • Knowledge of viscosity conversion formulas
  • Familiarity with ASTM D-445 testing standards
  • Basic principles of fluid density
  • Research the ASTM D-445 standard for kinematic viscosity testing
  • Learn how to convert kinematic viscosity to dynamic viscosity
  • Explore the impact of temperature on viscosity in fluids
  • Investigate viscosity measurement tools and techniques
Engineers, chemists, and automotive professionals involved in lubricant formulation and testing, as well as anyone interested in the properties of motor oils and their performance characteristics.
VooDoo
Hi guys,
For a prac we did, we are given the properties of a particular oil.
Density (kg/m^3) = 876
Viscosity (Ns/m^2) = 20.0x10^(-3)
I believe it is the dynamic viscosity. Now is this viscosity correct? Or should it be 2.0x10^(-3)
Kinematic viscosity 10.3 cSt = 10.3 E-6 m^2/s
To convert to kinematic to dynamic viscosity, multiply by the density,
Dynamic viscosity = 10.3 E-6 * 876 = 9.02 E-3 Ns/m^2 = 9.02E-3 Pa-s
If the dynamic viscosity is 45E-3 Pa-s at 40C and 9E-3 Pa-s at 100C,
the correct value for your experiment could be either 20E-3 or 200E-3 depending on the temperature.
  • · Replies 17 ·
