Thrown Upwards with one variable
  • Thread starter Thread starter sylenteck0
    Variable
The problem involves a stone thrown vertically upward, passing two points with different speeds. The original poster seeks to calculate the initial speed and the maximum height reached above a specific point, while grappling with the equations of motion and the implications of acceleration due to gravity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use kinematic equations but expresses difficulty due to the presence of multiple variables. They question how to incorporate time and initial velocity into their calculations.
Some participants have provided guidance on checking the relevant equations and emphasized the importance of sign conventions in the problem. Others suggest specific substitutions for the kinematic equations to facilitate solving for the unknowns, indicating a productive direction in the discussion.
There is a mention of potential confusion regarding the notation of the equations and the choice of positive direction for displacement, which may affect the interpretation of the problem.
sylenteck0
A stone is thrown vertically upward. On its way up it passes point A with speed v, and point B, 3.00 m higher than A, with speed 1/2 v. Calculate (a) the speed v and (b) the maximum height reached by the stone above point B.
Time in the sky= Initial Velocity/9.8m/s^2
Maximum Height= xmax = Initial Velocity^2/ 2 x (9.8/m/s^2)
I've been experimenting and can't seem to find an answer. I've tried using x+3+y to fill in for the maximum height, but I'll always end up more than one variable to solve for. Because deceleration would be at gravity, 9.8m/s^2, I was trying to figure out a way to even calculate a time, but without an initial velocity, it seems hopeless.
Thanks for the help :)
first check your relevant equations... they don't look right to me although they are written in some weird notation. check out the kinematics equations for constant acceleration at say
http://en.wikipedia.org/wiki/Kinematics
should be a good start (although no one should really take wiki seriously :smile:)
oh.. and of course, welcome to PF.
Thanks for the warm welcome, and I'll be sure to look it over :)
In all such problems be careful of the sign (+ or -) of different quantities. First decide the +ve direction for displacement. If the object is thrown upwards, it is logical to have upward displacement as +ve. However, if the object is thrown upwards from top of a tower, there is an option to have upward or downward displacement as +ve. Then, the velocities and accelerations in the +ve direction are also +ve. Acceleration due to gravity is always downwards. Hence, it will be +ve or -ve depending upon the direction chosen as positive. In the present case it will be -ve as upwards is +ve.
Consider motion of the stone from point A to point B. Use equation V^2 - Vo^2 = 2as and substitute Vo = V, V = V/2, s = 3m and a = - 9.8 m/s^2 and solve for V.
To get the max height reached above B, again use the above equation with substitution : V = 0, Vo = V/2 (for which now we have a value) and a = -9.8 m/s^2 and solve for s.
  • · Replies 38 ·
19K
