Convert space curve to cartesian
The discussion revolves around converting a space curve defined parametrically by R(t) = sinti + sqrt(2)costj + sintk into Cartesian coordinates. Participants explore the implications of this conversion, including the geometric interpretation of the resulting equations and the limitations of the approach.
  • One participant presents the parametric equations x = sint, y = sqrt(2)cost, z = sint and suggests eliminating t to find the Cartesian equation.
  • Another participant notes that while the equation x² + y² + z² = 2 holds, it oversimplifies the situation by suggesting a spherical structure rather than retaining the curve's one-dimensional nature.
  • A participant emphasizes the need to intersect with the plane x = z to accurately describe the curve, proposing the equation x = z = (1 - y²)^(1/2)/√2 as a more precise representation.
  • In response, another participant confirms the correctness of the proposed equation and requests clarification on how it is derived.
  • Further elaboration is provided, showing the relationships between x, y, and z and deriving the equation x = z = √(1 - y²/2) based on the parametric definitions.
Participants express differing views on the implications of the Cartesian conversion, with some asserting that the spherical equation is insufficient without additional constraints, while others provide derivations that support the proposed equations. The discussion remains unresolved regarding the best approach to fully represent the curve.
Limitations include the potential misunderstanding of dimensionality when transitioning from a curve to a surface and the need for further clarification on the derivation of the proposed equations.
yanyin
if R = sinti+sqrt(2)costj+sintk, 0<=t<=Pi/2
please eliminate t to determine the cartesian equation of R(t). Put limits on the variables and verbally describe the curve
x= sint, y=sqrt(2)cost, z=sint
u can clearly see that
x2 + y2 +z2=2{sin2t +cos2t}
=2
x2 + y2 +z2=2
And eqaully clearly, surely you can see there is more to it than that? You've just replaced a locally 1-d structure (a curve) with a locally 2-d structure, a sphere.
yes, the x, y, and z coordinates necessarily satisfy that, but that isn't sufficient. You need to intersect with the plane x=z (or similar) at the very least.
generally the equation is [tex]x=z=(1-y^2)^{1/2}/\sqrt 2[/tex]
Thanks matt grime, I've checked yours is correct.
but can you show me how the above equation is reached.
If matt grime will forgive me for sticking in my oar:
x= sint, y=sqrt(2)cost, z=sint so obviously x= z.
x2= sin2t= (1-cos2t). But
y2= 2 cos2t so cos2t= y2/2. That is x2= 1- y2/2 and
x= z= &radic;(1- y2/2).
