How Do You Calculate the Enthalpy Change for Methane Combustion?
  • Thread starter Thread starter salman213
    Combustion
The combustion of methane (CH4) can be represented by the balanced equation CH4(g) + 2O2(g) → CO2(g) + 2H2O(l). The standard heats of formation are ΔHf° of CO2(g) at -393.5 kJ/mol, H2O(l) at -286 kJ/mol, and CH4(g) at -74.8 kJ/mol. To calculate the enthalpy change (ΔH) for the reaction, the ideal gas law (PV=nRT) must be applied, considering the change in moles of gas. The total change in moles of gas is -2, which affects the volume calculations, although the volume of liquid water is negligible compared to gases.
  • Understanding of chemical thermodynamics
  • Familiarity with the ideal gas law (PV=nRT)
  • Knowledge of standard heats of formation
  • Basic principles of stoichiometry
  • Study the calculation of enthalpy changes using Hess's Law
  • Learn about the differences between gaseous and liquid states in thermodynamic calculations
  • Explore the concept of standard state conditions in thermodynamics
  • Investigate the implications of the ideal gas law on real gas behavior
Chemistry students, chemical engineers, and professionals involved in thermodynamic calculations and combustion analysis.
salman213
Enthalpy of Combustion -- Alkanes
Write a balanced equation for the combustion of CH4(g) (methane)
(its reaction with O2(g) forming the products CO2(g) and H2O(l)).
Given the following standard heats of formation:
[tex]\Delta[/tex]Hf° of CO2(g) is -393.5 kJ/mol
[tex]\Delta[/tex]Hf° of H2O(l) is -286 kJ/mol
[tex]\Delta[/tex]Hf° of CH4(g) is -74.8 kJ/mol
Calculate the difference, [tex]\Delta[/tex]H-[tex]\Delta[/tex]E=[tex]\Delta[/tex](PV) for the combustion reaction of 1 mole of methane.
(Assume standard state conditions and 298 K for all reactants and products.)
The ideal gas law must be used.
The incremental change in volume due to liquids is neglected (cf the volume of 1 mole of H2O(l) is 18 mL, whereas the volume of 1 mol of a gas at 298 K is about 24,450 mL.
Be careful to account for the total change in number of moles of gas molecules (be sure the signs and units are correct too).
Note that certain alkanes are gases in the standard state.
My balanced equation was CH4 (g) + 2O2 (g) ---> CO2 (g) + 2H2O (l)
it says use PV=nRT but i was confused about the change in moles like is it just the change in moles of the GASES so molesfinal - molesininitial = 1 - 3 = -2 ?
and then
(-2)(0.08206)(298) = the difference...?
but i think that's wrong!
The number of moles doesn't change - for each mole of CH4 and two moles of O2, one mole of CO2 and 2 moles of H2O are produced. If the reactants start at STP, the products would certainly not, but the problem states
but, think about the fact that one is given H2O (l) as opposed to H2O (g), which would occupy a greater volume. Compare the volume of liquid water to vapor.
huh? sorry i don't really understand what i need to compare..
'The incremental change in volume due to liquids is neglected (cf the volume of 1 mole of H2O(l) is 18 mL, whereas the volume of 1 mol of a gas at 298 K is about 24,450 mL. "
i thought volume didnt matter since it was neglected :S
