Why Is the Pump Located at the End of the Reservoir System?
  • Thread starter Thread starter ko_kidd
    Pump Tank
The discussion revolves around a pump system connected to a reservoir and an open-air tank. The original poster expresses confusion regarding the placement of the pump at the bottom of the tank and questions the logic behind this setup, particularly in relation to gravity feed systems.
  • The original poster attempts to understand the role of the pump in the system and is uncertain about how to calculate outflow. Some participants suggest considering the function of water towers and the pressure dynamics involved in water distribution.
Participants are exploring the implications of the pump's location and its relationship to gravity feed systems. Hints have been provided regarding the function of water towers and pressure, but there is no explicit consensus on the best approach to the problem.
The original poster notes a lack of clarity in the problem statement regarding the pump's connection and function, which may affect their understanding of the system's operation.
ko_kidd
Tank Problem -- Pump at the END?
I will try to post more relevant data if possible but my main issue is this:
I have a pump that receives water from a reservoir--so basically a gravity feed into an open-air tank.
The tank itself is supposed to feed into a pump (that is located at the very bottom of the tank horizontally extending from it).
I have never seen anything like this, it doesn't seem logical to have any sort of pump at the end of a reservoir when you could use a pump for just getting water into a tank and let gravity do the rest.
There is no mention of whether or not the pump is connected directly to the thing and/or feeds into another tank for the pump or if it just stops inside some sort of pump and just goes out to the town.
The paper literally says "The outflow of the tank is through a pump that pressurizes the distribution network throughout the town."
I think I can figure out most of the problem, but the way to calculate outflow is confounding me right now.
If it's a pump sucking out water, that's one thing--if it's just gravity feeding a pump, that's another thing.
Here are a couple of hints:
When you drive around to some very flat places, why do you see tall water towers?
What possible function could the pump serve?
Okay.
From what I've read, the towers are so high so that you can get a lot of pressure in the line to drive the water out to people's houses.
And pumps are before those tanks, so that they can provide water at a definite pressure down the lines to peoples' houses and so that they can refill the towers so that the pump doesn't have to be huge.
HOWEVER, my problem is not that similar to this. I'll show you the diagram of my problem (what I was given):
What does the problem ask you to find exactly? The output (flowrate) of the tank to the pump possibly?
  • · Replies 24 ·
