Angular Variables and Tangential Variables
  • Thread starter Thread starter needhelp2008
    Angular Variables
The discussion focuses on calculating the angular speed of a fishing reel based on the linear speed of the fishing line being wound onto it. Given that 2.6 meters of line is wound in 8.4 seconds and the radius of the reel is 3.0 cm, the angular speed can be determined using the formula v = r * ω, where ω represents angular speed. The linear speed of the line is calculated as 2.6 m / 8.4 s, leading to an angular speed of approximately 10.36 radians per second.
  • Understanding of angular velocity and linear velocity concepts
  • Familiarity with the formula v = r * ω
  • Basic knowledge of units of measurement (meters, seconds, radians)
  • Ability to perform unit conversions (e.g., converting radius from cm to meters)
  • Learn about rotational dynamics and the relationship between linear and angular motion
  • Explore the concept of torque and its effect on angular acceleration
  • Study real-world applications of angular speed in mechanical systems
  • Investigate the effects of varying radius on angular speed calculations
Physics students, mechanical engineers, and anyone interested in understanding the principles of rotational motion and angular speed calculations.
needhelp2008
In 8.4 s a fisherman winds 2.6 m of fishing line onto a reel whose radius is 3.0 cm (assumed to be constant as an approximation). The line is being reeled in at a constant speed. Determine the angular speed of the reel.
don't know where to start?
Start with this.
If a disc spins, then the linear speed v of a pt on the circumference is given by v=r*w, where w(omega) is the angular speed of the disc.
9K
16K
