How Does Blood Temperature Change During Exercise?
  • Thread starter Thread starter phobia
    Blood Temperature
The discussion focuses on the calculation of blood temperature changes during exercise, specifically when 0.671 kg of blood releases 1860 J of energy at the body's surface temperature of 37.0 °C. Participants clarify that the specific heat capacity of blood is assumed to be equivalent to that of water. The correct approach involves calculating the temperature change using the formula ΔT = Tf - Ti, where Tf is the final temperature and Ti is the initial temperature. The final temperature is determined by subtracting the calculated temperature change from the initial temperature of 37.0 °C.
  • Understanding of specific heat capacity, particularly in relation to water.
  • Familiarity with basic thermodynamics and energy transfer concepts.
  • Ability to manipulate and solve algebraic equations.
  • Knowledge of temperature measurement in degrees Celsius.
  • Study the specific heat capacity of various fluids, focusing on blood and water.
  • Learn about energy transfer mechanisms in biological systems during exercise.
  • Explore thermodynamic principles related to temperature changes in fluids.
  • Investigate the physiological responses of the human body to exercise and temperature regulation.
Students in biology or physiology, exercise scientists, and healthcare professionals interested in understanding the physiological effects of exercise on body temperature regulation.
phobia
Question:
Blood can carry excess energy from the interior to the surface of the body, where the energy is dispersed in a number of ways. While a person is exercising, 0.671 kg of blood flows to the surface of the body and releases 1860 J of energy. The blood arriving at the surface has the temperature of the body interior, 37.0 °C. Assuming that blood has the same specific heat capacity as water, determine the temperature in degrees Celsius of the blood that leaves the surface and returns to the interior.
Attempt
From the equation:
http://img150.imageshack.us/img150/3461/math052rc5.gif
I get the change in temperature. Since I am given initial temperature all I need to do is take the change in temperature and add the initial temperature:
(change)TEMP = Tf-Ti
Problem:
I'am not getting the right final temp.
The blood at the surface of the body has lower temp. Are you taking the positive value of delta_t and subtracting it from 37?
Thanks problem solved.
9K
28K
