How Long Should Al Alloy Ribbons Be Heat Treated?
Heat treating Al alloy ribbons with a thickness of 0.01 to 0.025 inches requires the same parameters as those used for thicker samples. The recommended heat treatment cycle includes solutionizing at 540°C for 16 hours, followed by quenching in room temperature water, and aging at 190°C for 48 hours. The key factor in this process is the diffusion of atoms, which necessitates maintaining the established timeframes for effective treatment.
  • Understanding of heat treatment processes for aluminum alloys
  • Knowledge of solutionizing and aging treatments
  • Familiarity with quenching techniques
  • Basic principles of atomic diffusion in materials science
  • Research the effects of varying thickness on heat treatment outcomes for aluminum alloys
  • Explore advanced techniques for monitoring atomic diffusion during heat treatment
  • Investigate alternative aging temperatures and times for Al alloys
  • Learn about the impact of quenching mediums on the properties of heat-treated materials
Materials scientists, metallurgists, and engineers involved in the heat treatment of aluminum alloys, particularly those working with thin materials.
iti
I am going to heat treat Al alloy ribbons of low thickness (about 0.01 to 0.025 in). Could you please suggest me the time needed for solutionising as well as aging treatment if my heat treatment cycle for thick sample is as follows?
Solutionization – 540C for 16 hrs
Quench – Room temperature water
Aging 190C for 48 hrs
Thanking You
ITI
Hi,
in my opinion you need use the same parameters.
Heat treatment main idea is the difussion of the atoms, so there is the time needed for this process.
17K
  • · Replies 21 ·
