Can a LRC circuit produce a net magnetic field with zero net charge flow?
The discussion centers on whether an LRC circuit can produce a net magnetic field while maintaining zero net charge flow. Participants explore the implications of current flow and magnetic field generation over time, considering both theoretical and practical aspects of circuit design.
  • One participant proposes a scenario where an LRC circuit alternates between a positive and negative current, suggesting that this could lead to a net positive squared magnetic field despite zero net charge flow.
  • Another participant points out a mathematical error regarding the squaring of negative current values, emphasizing that the square of -10 milliamps should be +100, not -100.
  • A participant suggests that the time average of the squared magnetic field could yield a net positive value, thus supporting the initial claim of generating a magnetic field without net charge flow.
  • One participant challenges the notion that a system with zero net charge flow can perform net work, arguing that this contradicts the operation of AC powered induction motors.
Participants express disagreement regarding the feasibility of generating net work from a system with zero net charge flow. While some explore the mathematical implications of current flow and magnetic fields, others assert that the initial premise is flawed based on established principles of electromagnetism.
Participants reference earlier discussions about transformers and motor configurations, indicating a broader context of electrical engineering principles that may influence their arguments. However, the specific details of these earlier discussions are not fully elaborated in the current thread.
kmarinas86
Let's say for the:
First 10 milliseconds: Current is 1 milliamp. The squared magnetic field resulting we will call "default".
1 millisecond following, last millisecond: Current is -10 milliamps. The squared magnetic field is -100 * "default".
The time average square of the magnetic field corresponds to: 10 * 1 - 1 * 100 = -90
One could then imagine the ability for an electromagnetic field made this way to do net work with zero net charge flow, provided that the time constant of the wire is larger than 10 milliseconds. Capacitors could easily increase the time constant of the circuit. The capacitors could be lined up in circuit with a low voltage battery. The circuit could intermittently connect and disconnect a higher voltage, higher current battery with the opposite polarity for a fraction of the time. If timed precisely, the charges would travel back in forth through the wire in a linear way while producing time-average squared magnetic field that is positive.
Something is wrong.
Something is wrong.
One thing that is wrong is that the square of -10 is +100, not -100.
The rest of your post is difficult to follow. I can't tell what you're trying to say.
Does this have something to do with an earlier post where you were putting the primary and secondary of a transformer in series with a motor and commutator?
It would help if you would provide a schematic (not a picture, but a regular schematic) and tell us what you're trying to do.
Right. But this misses an important part of my point of flipping the sign. Let's go with the positive sign and see what happens:
10 * 1 + 1 * 100 = 110
To take the average we get:
110/11 = 10
So we get a net squared magnetic field without a net flow of charge.
No
Right now I'm not trying to do anything. I just need proof that a system that has 0 net charge flow can't do net work.
You won't find any such proof because it isn't true. In fact, it would appear that you have just proved that it isn't true.
If it were true, then AC powered induction motors wouldn't work.
9K
