Electric dipole's maximum angular velocity
The discussion focuses on calculating the maximum angular velocity (\(\omega_{max}\)) of an electric dipole in an electric field. The dipole consists of charges +q and -q separated by a distance D, with a moment of inertia I about its center of mass. The relevant equations include the dipole moment \(p = qD\), torque \(\vec{\tau} = \vec{p} \times \vec{E}\), and potential energy \(U = -\vec{p} \cdot \vec{E}\). The solution involves equating potential energy to kinetic energy to derive the maximum angular velocity when the dipole aligns with the electric field.
  • Understanding of electric dipole moment and its calculation
  • Familiarity with torque and its relation to angular motion
  • Knowledge of potential energy in electric fields
  • Basic principles of rotational dynamics, including moment of inertia
  • Study the relationship between potential energy and kinetic energy in rotational systems
  • Learn about the dynamics of electric dipoles in varying electric fields
  • Explore the concept of angular momentum and its conservation in electric dipole systems
  • Investigate the effects of different charge distributions on dipole behavior
Students and professionals in physics, particularly those studying electromagnetism and rotational dynamics, as well as educators looking for practical examples of electric dipole behavior in electric fields.
superamazinPI
Consider an electric dipole located in a region with an electric field of magnitude [tex]\vec{E}[/tex] pointing in the positive y direction. The positive and negative ends of the dipole have charges +q and -q, respectively, and the two charges are a distance D apart. The dipole has moment of inertia I about its center of mass. The dipole is released from angle [tex]\theta[/tex], and it is allowed to rotate freely.
What is [tex]\omega_{max}[/tex], the magnitude of the dipole's angular velocity when it is pointing along the y axis?
dipole moment p= qd
[tex]\vec{\tau}[/tex]=[tex]\vec{p}[/tex]X[tex]\vec{E}[/tex]
U= -[tex]\vec{p}[/tex] [tex]\cdot[/tex][tex]\vec{E}[/tex]
I attempted to use energy, but I am not sure how to do it correctly - does potential energy equal kinetic? is the potential energy the one described in the above equation?
dipole in a E field gives torque, torque is a force and can then be related to moment of inertia and angular acceleration
You can use your expression for U and (1/2)I\omega^2 for the KE.
12K
