What Gear Ratio Should I Use for Maximum Speed on My Model Car?
  • Thread starter Thread starter 9988776655
The discussion revolves around determining the appropriate gear ratio for maximizing the speed of a model car. Participants explore the implications of different gear ratios, the specifications of the motor and gearbox, and the physical characteristics of the model car, including its weight and wheel size. The conversation includes technical calculations and considerations related to torque, speed, and the overall design of the vehicle.
  • One participant inquires about the best gear ratio for maximum speed, providing details about the car's mass, wheel size, and gearbox ratios.
  • Another participant questions the necessity of a gearbox for an electric motor, suggesting that the proposed gear ratios may be excessive.
  • A participant calculates the required torque for the car and discusses the impact of using four wheels on torque calculations, expressing uncertainty about the efficiency of spur gears.
  • Concerns are raised about the suitability of the gearbox for the intended application, with suggestions that it may be designed for robotics rather than model cars.
  • Participants debate the implications of using a high gear ratio (1300:1) on acceleration and speed, with one noting that it would result in very low output shaft speed.
  • Clarifications are made regarding the size of the model car and its components, with some participants suggesting that the motor may not provide enough power for effective performance.
  • One participant expresses frustration with their university education, feeling unprepared for practical applications in mechatronics.
  • Another participant challenges the calculations of speed based on wheel size and revolutions per minute, indicating discrepancies in the results.
Participants do not reach a consensus on the best gear ratio or the adequacy of the motor and gearbox combination. There are multiple competing views regarding the appropriateness of the gear ratios and the expected performance of the model car.
Limitations include potential inaccuracies in torque and speed calculations, assumptions about the efficiency of components, and the overall design constraints of the model car. The discussion reflects varying levels of understanding and experience among participants.
Individuals interested in model car design, remote-controlled vehicles, or those studying mechatronics and engineering principles may find this discussion relevant.
9988776655
Im building a model car with mass 0.3kg. I am thinking of buying a fancy 6 speed gearbox. But before I spend my money, I need to know if any of the gear ratios are going to move my little car.
Here is the motor:
the gearbox has ratios:
11.6:1
29.8:1
76.5:1
196.7:1
505.9:1
1300.9:1
If I wanted maximum speed, but I want my car to run, which gear ratio should I use?
I have four wheels, each 0.0028m in radius. I am using a 3V battery. The gearbox drives an axle which runs through two wheels. The torque applied by the axle is through the centre of rotation. The coefficient of rolling friction between the ground and the tire is about 0.01, maybe a bit less since the tires are so small.
I know that F = umg where u is the coefficient of friction but that's it. Please teach me how to work out a similar problem for next time. I have a feeling that I will be building a lot of model cars in the future.
I must admit that I'm a bit baffled by the question. The one serious advantage of an electric motor over an IC one is that you don't need a transmission.
Your ratios look way out of whack to me, as well. Are you trying to get this thing supersonic or pull stumps with it?
So any gear ratio will work? well my car is also remote controlled and it has steering which will be pretty impressive. Ill put a picture up when its done.
I don't see how they gear ratios are out of whak. All I want is a fast little car to race my friend's one. Here is the product specification:
http://www.tamiyausa.com/product/item.php?product-id=72005"
If my vehicle weighs 0.3kg and all the weight is in the middle and it is 0.2m long, the required torque from my axle is:
Mo = mgL
Mo = 0.1m*0.3kg*9.8m/s
Mo = Required torque = 0.294Nm
But I have 4 wheels but i don't know how this effects my torque calculation.
working torque = stall torque / 2 <------ should i rather use torque at maximum efficiency here as given in the motor spec in previous post?
= 0.00686N / 2
= 0.00843N
Gear ratio = required torque / working torque
Gear ratio = 0.294N / 0.00843N
= 34.9:1
But my spur gears arnt that efficient
Would this calculation be correct??
I think that I see the difficulty here. (There are a lot of other people here who know far more about it, though, so don't take me at my word.) That gearbox appears to be intended for robotic applications, where you might need incredible torque increases over what the motor itself could provide directly.
Have you even considered checking the math to see how fast your little car would go with a 9,400 rpm motor geared down 1,300:1? As I said, it would be a stump-puller, except you wouldn't have any traction to make use of the torque. If you had the tranny installed backwards, as I originally thought that you meant, you wouldn't have enough torque to push a feather out of your way, but you'd have the sucker moving like greased bacon through a goose's ass once it managed to accelerate.
So it would go pretty swiftly but will it be able to accelerate with 1300:1?
This "R/C" car you're planning on building sounds like its WAY smaller than any standard racing R/C car I've ever heard of... we're talking even smaller than those little Zip-Zaps miniature R/C cars you can buy at Radio Shack. The tires are only 5.6mm in diameter?! This thing is going to be way smaller than that transmission by itself, and like Danger said, it doesn't look like it is made for a car application that is shift-on-the fly.
I the same vein, it sounds like that motor you have specced out doesn't have much power at all... 1/10th scale race-quality motors for competition typically put out at least 50-100times as much torque, and 50 times as much total power using up to a 7.2V battery; and they rev up to over 20,000rpm.
I would recommend browsing around www.towerhobbies.com for some ideas. They have lots of kits and race/hobbby specific products for R/C vehicles.
they are 5.6cm diameter maybe i put the decimal point in the wrong place oops. I thought the motor had a bit more power than that. Maybe i need buy a more powerful gearbox/motor combination. I thought since my car was only 20cm long and weighs 300g all up a weak motor would be okey
That kind of reduction would give you an output shaft speed of only 5.8rpm, useless for anything that wants to go faster than a slug.
Even assuming direct drive to the axle after the transmission, 5.4rpm would equate to about 10cm/min. The "minimum" reduction in that transmission would equate to about 20cm/s (7 in/s); not very fast in my opinion, but maybe fast for such a small vehicle.
Again, it sounds to me like this "transmission" will be larger than the rest of your car combined.
9988776655 said:
they are 5.4cm diameter maybe i put the decimal point in the wrong place oops. I thought the motor had a bit more power than that. Maybe i need buy a more powerful gearbox/motor combination
What kind of R/C racing are we talking about here? The real deal, or just for fun with home made stuff? How big is the car supposed to be?
thats way too slow but at least it can accelerate. I tried to work it out before and I got that 34.9:1 would be a good ratio so I would pick the only one close to that 76.5:1 which the gearbox offers. Thats 100 rpm. Would that be able to drive the car or do you think I need a more powerful gearbox/motor? Its for fun. It can be whatever size but of course i need it big enough to fit a receiver pcb, batteries and the gearbox itself. I am using plywood as a chassis. I am in second year uni doing mechatronic engineering but all they teach me is programming, maths and statics. What is the use of that?
No, it can't. That's maximum linear speed with the motor running at its maximum speed with no load.
How did you choose that "good" ratio? Based solely on friction (which you have calculated incorrectly)? You're going to want a motor and gear combo that gives you WAY more power and torque than would be required to overcome friction, so that your car actually accelerates and can maintain a top speed.
9988776655 said:
Thats 100 rpm.
That's 2.9 cm/s based on the numbers you've posted thus far. Slow. Real slow.
9988776655 said:
Would that be able to drive the car or do you think I need a more powerful gearbox/motor? Its for fun. It can be whatever size but of course i need it big enough to fit a receiver pcb, batteries and the gearbox itself. I am using plywood as a chassis. I am in second year uni doing mechatronic engineering but all they teach me is programming, maths and statics. What is the use of that? My uni friends are having a race day in a few months
There's no way you're gonig to keep your vehicle weight under 0.3kg including batteries and electronics while building the vehicle out of plywood. I would guess at least triple that weight depending on overall size.
It sounds to me like your estimates and calculated numbers are all WAY off right now. My recommendation is to look at some cars that already exist, at a hobby shop for example, to get an idea of what size you're looking for, what driveline components you'll want, and how you plan to accomplish it.
I feel a little hopeless after your post
My wheel is 5.6cm diameter, circumference 17.6cm.
My revolutions per minute is 100
My revolutions per second is 1.67
Every revolution, My wheel turns 17.6cm
My distance per second is 1.67r/s * 17.6cm = 29.5cm/s
But you got 2.9 cm/s? am i missing something?
You are right about my estimates being way off. It would me nice to actually know how to do the "torque required" calculation correctly but I don't know how.
I can't find a more powerful gearbox/motor combo
Im looking at another gearbox which may be just as bad. You can do
1:125
Does that mean for every 1 motor revolution, the axle turns 125 times?
9988776655 said:
You can do
1:125
Yes. So figure what that means with your 9,400 rpm motor.
I think ill pass on that gearbox then. I don't think 29cm/s is slow. But maybe i didnt work it out properly. To overcome friction initially I need:
torque > Us*m*g
torque > 0.4*0.5kg*9.8m/s
torque > 1.96N
(I used an estimate for the friction of rubber on wood)
Rolling friction has to be less than this
But I have 4 wheels so I don't know how that effects friction
Even with the highest reduction, my gearbox/motor still won't even move
No need to feel hopeless, we are here to help. I suspect you'll be able to build a very capable vehicle once we get a few basics ironed out.
Well there's the problem, your original post said the wheel radius was 2.8mm (0.0028m), so there was an extra zero in there.
Well, I think your problem is that you're not really grasping what the friction calculation is useful for.
What you want is this thing to be fast, so you're going to want to accelerate at a decent rate, which means the majority of your motor's power will go towards accelerating the vehicle's mass. As long as all of the parts are chosen properly, friction should be a negligeble effect when compared to the required acceleration force.
1:125
That is the reverse of what you would use a gearbox for. Since you're going to be using a small, fast-revving motor, the gearbox needs to be used to REDUCE the rotational speed, not increase it. So if you were using a gearbox with a 1:125 ratio, the output shaft of the gearbox will turn once for every 125 turns of the motor.
Are you going to be using a differential for the drive wheels, or will the output of the gearbox directly drive the rear wheels?
It's all a matter of perspective. I have a "stock class" 1/10 scale electric off-road race buggy that easily goes 25 mi/hr, which works out to about 11 m/s (1100 cm/s). A 1/8th scale nitro-powered monster truck I have can hit a top speed of about 40 mi/hr (17 m/s, 1700 cm/s), even faster with different gearing.
What kind of a race are we talking about? On-road, off-road, parking lot, table top, etc?
torque > Us*m*g
torque > 1.96N
YOU'RE NOT CALCULATING THE RIGHT KIND OF FRICTION. Static friction (what the above calculation you did is for) would be if the wheels were locked up, not rolling, and you were dragging the vehicle along the ground.
For your purposes, I would first assume friction to be negligible, and instead decide how fast you want your vehicle to accelerate to its final top speed. Then, using kinematics, you can figure out how much force would be required to accelerate it that quickly. From there, a motor can be chosen and a gear reduction can be decided on based on a required final top speed and acceleration.
To give you a better idea of what you should be looking for, start here:
http://www3.towerhobbies.com/listings/cat-c2.html
That is a basic listing of R/C car parts at tower hobbies, which should be very useful. They have tires, motors, bodies, controllers, servos, everything. In my opinion, it sounds to me like you wil want a "stock" 17 turn motor and regular speed controller, since they will be cheap, and far more powerful than the motor you currently have specced.
Motor Examples:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKCD0&P=0"
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGKC7&P=0"
Im thinking of using the gearbox that I was originally looking at but replacing the motor with of the ones you suggested. The gearbox is meant for a 2mm shaft but the 18-turn motor is 3mm. I do not know the diameter of the 17-turn motor. Do these motors also run on 3V?
The car is going to be on-road.
I thought to make the output shaft of the gearbox run the wheels.
I don't really need a speed controller. I am happy with max speed all time.
I worked out that the small components+wood+batteries+gearbox is 527g. If we change the motor it could be a bit heavier.
I don't think that gearbox will be a very good application for what you're trying to do. As said before, it looks to be more of an automation/robotics application for low speeds and forces.
While it's theoretically possible to run on 3V, why not just buy a single 6.4-7.2V battery pack? They're cheap, and specifically designed to work with the high current draw of this kind of motor.
Commonly the gear reduction used with these specific motors is a spur and pinion gear combination that drives a transaxle differential (combined transmission/differential), which in turn drives the wheels. Common pinion/spur ratios are around 1/3 to 1/4 (for example, a 78 tooth spur gear and a 24 tooth pinion gear, you can select different options to suit your driving style) and the transmission might be about 1/2.6, making the output speed to the wheels about 1/7 to 1/10 that of the motor's output speed. That setup (primarily off-road) would normally be used with 8.89 cm diameter drive tires, that are 6.1cm wide. On-road applications would be faster (less total gear reduction) with slightly smaller diameter tires.
But how? You're going to need some sort of transaxle at very least to make the single output into dual axle shafts...
Basic speed contrtollers are cheap, and these motors cannot be run without some sort of speed control. It is the throttle for the motor, so you can slow down in turns, and accelerate on straight aways. You have to remember it's going to have a pretty fast top speed and running with an on/off switch to the battery isn't really an option.
My guess without any calculation at all is you should aim for about double that, at least.
I thought about this differential:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBME7&P=7#otheritems
I also found these preassembled versions:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSXA9&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXLXX4&P=7
But I don't know what pinion gear to get to fit between the motor and the differention and I don't have housing for the differential. Why don't they include a pinion gear and housing set?
You're on the right track. Some R/C cars or trucks will have a transaxle that essentially houses the transmission and differential together, while other ones have separate differentials and transmissions.
It might be worth looking into parts for a Traxxas E-Maxx or T-Maxx, they have separate transmissions and differentials, and transmissions are available in single or dual speeds for the electric version of the truck.
The traxxas differentials have many parts to put together.
What do you think of this combination instead:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSWW1&P=Z
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAMH5&P=Z
Do I need any other components? I can buy steel rods and a battery from another place cheaper and I have wheels already as well.
I hate to tell you now, but if you're looking to build a functioning R/C car, being afraid of putting a lot of parts together is probably not a good thing...
The motor you linked might be a little on the big side, but would still work (it's made for a monster truck it looks like). The differential "assembly" is the gear, bearings, and output shaft, but you will still need the entire transmission assembly and plastic housing that all of that goes in. you can't just drive the 'differential" directly with the motor, you need an interface between the two.
I would suggest looking up the exploded drawings of some stadium trucks or monster trucks such from companies such as Team Associated, Losi, or Traxxas (Traxxas has very easy to read drawings for our purposes). They are available free online, and will show you how the parts go together. For the Traxxas E-Maxx for example:
http://www.traxxas.com/products/electric/emaxx/trx_emaxx_views.htm#manual
You can see that it has a motor mount/transmission assembly that then has an output driveshaft that goes to the front and rear differentials (4WD). While it has the option for 4wd and two motors, it would be pretty easy to use just one motor with the transfer case, and then a single differential in the rear to put power to the ground. The nice thing about the Traxxas differential is it has it's own case, and can then be mounted where as the differentials you are finding go inside the case of the transmission/transaxle.
For an integrated transmission transaxle, you can see how it goes together on something like the Traxxas Rustler:
http://www.traxxas.com/products/electric/rustler/trx_rustler_views.htm#manual
Looking at the Rustler's Transmission assembly, you can see that the differential, motor mount, and "trasmission" are all combined into a single unit. So, if you bought a used (or new) complete Rustler transmission assembly, you would have everything you needed to put power to the ground on a rear wheel drive vehicle. All you need in addition to that would be a motor (and spur gear) and speed controller, and your radio receiver equipment. Then you would have to just try and mimic the truck's body mounts on the back that the transmission assembly mounts to.
In addition to the off-road trucks I linked, which are designed with long axle shafts and big suspension travel in mind, Traxxas also makes some street vehicles, such as:
http://www.traxxas.com/products/electric/streetsport/trx_streetsport_views.htm#manual
You can see that the Street Sport is a sort of a NASCAR model that has a transmission very similar to the Statium truck, just smaller suspension travel. The street truck they make:
http://www.traxxas.com/products/electric/spirit/trx_spirit_views.htm#manual
The Spirit actually has NO suspension travel in the back because the entire transmission assembly pivots up and down, the wheels mount to the transmission directly. That might be one of the easiest integrations just because you don't necessarily need any shocks or suspension components.
  • · Replies 23 ·
12K
