Water pumping in tall buildings ?
  • Thread starter Thread starter Cliff_J
    Water
The discussion revolves around the challenges and solutions related to pumping water in tall buildings, particularly in the context of pressure requirements and piping configurations. Participants explore various methods to efficiently manage water distribution across multiple stories, drawing comparisons to elevator systems and mining operations.
  • One participant suggests using a collection pool every 40 stories to reduce pressure requirements and piping complexity, while acknowledging that this approach may lower efficiency due to multiple pumping steps.
  • Another participant agrees that using collection pools can mitigate pressure issues, but notes that the total horsepower required to pump water to the top may remain the same or increase.
  • A different viewpoint proposes that inline pumps could be used without the need for collection pools, emphasizing that the pressure gain from each pump can be designed to support specific height columns of water.
  • One participant highlights the relevance of this problem in deep mining scenarios, where the height differences and potential consequences of failure are significantly greater than in buildings.
  • Another participant points out the importance of check valves in the pump discharges to prevent issues when intermediate pumps are off, as the static pressure would otherwise affect the bottom pump and piping system.
Participants express differing views on the necessity and efficiency of collection pools versus inline pumps. While some agree on the benefits of collection pools for managing pressure, others argue that inline pumps could suffice without them. The discussion remains unresolved regarding the optimal approach.
Participants acknowledge the complexity of fluid mechanics and the historical context of pumping technologies, particularly in mining. There is an implicit understanding that various assumptions about efficiency and pressure dynamics are at play, but these are not fully explored or resolved.
Cliff_J
Ok, read the solar tower stuff in a couple threads here, and the complexity of pumping water to great heights in terms of pumping losses and pipe requirements surpized me. So, thinking about the skyscraper express elevator/floor elevator setup like the WTC had seems applicable to water.
Obviously we can calculate (and govt regulated) on how much pressure and piping we need to pump water a given amount, say 40 stories but to get to 80 or 120 stories, our requirements would normally change by some square or cube factor. But what if like the express elevator the orignal 40 stories pumped into a collection pool, and then we repumped the next 40 stories and so on. Would our original 40 story requirements be sufficient for each additional 40 story step?
Sure our efficiency is lower since we have so many repetitive pumping steps, but leaving that aside wouldn't this lower the piping requirements tremendously and also have some small efficiency recovery in the lower pumping pressures needed?
Cliff
Yes. this is one way to overcome the tremendous water pressure of tall buildings. Everytime there is an air break, the pressure requirements are renewed, so the only static head is from the water directly above to the next pool above. This solves the pressure restrictions on the piping and pumps, however, it will still require as much or more horsepower to lift the amount of water required to the top of the tower.
You can just put a pump inline every 40 stories, or whatever. There really isn't much need for a collection pool unless you need one for efficiency/pressure reasons.
This type of problem is much more interesting in deep mines where the height difference (and consequences of failure) can be a good lot more spectacular. Some mines are more than a mile deep, which is a good sight more height difference than buildings provide.
Ok, so an inline pump accomplishes the same because its all about the pressure gain from the pump that could be designed so each pump/pipe only supports a column of water X feet tall then. And here I thought fluid mechanics was tough...
Yes, the mine thing is quite amazing, and I forgot that mining was the impetus for steam engines and horsepower and what not. Astoundingly, I can't believe what was accomplished before the 20th century's knowledge and technology expansions. And the danger level is unreal to me - one of the History channel shows on man-made disasters showed footage of a salt mine under a lake that was accidentally drilled by an oil company. Wow!
Cliff
Actually, it's the check valves on the pump discharges that allow this arrangement to work. Otherwise, should the intermediate pumps be off for some reason the full static pressure of the column of water would rest on the bottom pump and pipe system.
  • · Replies 39 ·
18K
9K
