Solve Sin((pi*x)/6) >= (x/2) with Mean Value Theorem
The discussion revolves around solving the inequality sin((π*x)/6) ≥ (x/2) for the interval 0 ≤ x ≤ 1, utilizing the Mean Value Theorem. Participants explore various approaches and reasoning related to the application of the theorem and the behavior of the function involved.
  • One participant expresses confusion about applying the Mean Value Theorem and notes that f'(c) is negative for some values in the interval.
  • Another participant proposes defining f(x) = sin((π*x)/6) - (x/2) and suggests that if f(0) - f(1) = 0, then checking f(1/2) could indicate the sign of f(x) over the interval.
  • A challenge is raised regarding the assumption that f(x) being positive or negative at a single point implies the same for the entire interval, emphasizing the need to show there are no zeros in [0,1].
  • Some participants discuss the implications of the Intermediate Value Theorem (IVT) and whether the product f(a)f(b) being non-negative allows for the conclusion that there are no zeros in the interval.
  • One participant attempts to derive conditions under which f'(c) could be shown to be non-negative, but expresses confusion about the results, particularly at specific points like c=0.6.
  • Another participant explores the critical points of f(x) and suggests that if there is only one critical point in (0,1), it indicates a maximum, which could support the claim that f(x) > 0 in that interval.
  • A later reply questions the calculation of critical points, suggesting a possible oversight in the derivation.
Participants exhibit disagreement on the implications of the Mean Value Theorem and the necessity of showing that f(x) does not change sign throughout the interval. There is no consensus on the sufficiency of the arguments presented, and the discussion remains unresolved regarding the validity of the approaches taken.
Some participants note the importance of confirming the behavior of f(x) across the entire interval, not just at endpoints or a midpoint. There are unresolved mathematical steps regarding the critical points and their implications for the function's behavior.
maryk
Mean Value Theorem Please Help!
Hi there, hopefully someone can help me I'm completely lost!
I'm trying to solve sin((pi*x)/6) >= (x/2) for o<= x <= 1
using the mean value theorem.
I think I need to show that f ' (c) >= 0, however this f ' (c) is negative for some values in the interval? HELP!
ok, if you are trying to prove that:
[tex]sin\frac{x\pi}{6}\geq \frac{x}{2}, 0\leq x \leq 1[/tex]
so let
[tex]f(x)=sin\frac{x\pi}{6}- \frac{x}{2},[/tex]
we notice that [tex]f(0)-f(1)=0[/tex] now we take any point on the interval
[tex]0\leq x \leq 1[/tex] say [tex]x=\frac{1}{2}[/tex], then if f(x) is positive or negative, it actually will meant that f(x) is either positive or negative on the whole interval [tex]0\leq x \leq 1[/tex]
[tex]f(\frac{1}{2})=sin\frac{\pi}{12}-\frac{1}{4}>0[/tex] so
[tex]f(x)=sin\frac{x\pi}{6}- \frac{x}{2}>0=>sin\frac{x\pi}{6}\geq\frac{x}{2},[/tex]
Well,i don't know whether this answers the requirements of the problem though. Sorry!
This is not true in general, you also have to show that there are no zeros in [0,1]. It is not enough, that f vanishes at the end points.
I think we can be sure that there are no zeros on [0,1] since the function f(x) does not change sign at the endpoints. Am i right?
From the IVT we know that if f(a)f(b)<0, than there exists a poing cE(a,b) such that f(c)=0. But since f(a)f(b) is not <0 in our case, can we safely assume that there is no point cE(a,b) such that f(c)=0 ?? I think we can.
I think it doesn't matter whether or not f "changes sign at the endpoints".
You're right that f(a)f(b)<0 ensures the existence of an c in [a,b] with f(c)=0. The converse is not true. What you can probably easily prove is that f(a)f(b)<0 iff there is an odd number of zeros (counted with multiplicity) in [a,b].
A counterexample to your reasoning would be [a,b]=[0,10 pi], f(x)=sin(x), Then f(a)=0=f(b), but there is a bunch of zeros in [a,b].
Oh,yeah, i see now!
Thanks for your help everyone, think I need to show that it is true for every point within
0<= x <= 1, not just the endpoints and a point in the middle of the interval.
I was thinking the working should start as follows:
f(x) = sin ((pi*x)/6) - (x/2) and we need to show this greater than or equal to zero.
f ' (x)= (pi/6)cos((pi*x)/6) - 1/2
since f(0)=0, we can rearrange the mean value theorem in the form:
f(x) = x f ' (c),
where f ' (c) from above is (pi/6)cos((pi*c)/6) - 1/2 for some c between 0 and 1.
Therefore if i can show f ' (c) is greater than or equal to 0 for c between 0 and 1, then f(x) will also be greater than or equal to zero since we will have x times this where x is between 0 and 1. However, we are working in radians and f ' (c) is negative for c=0.6, for example. Soooo confused any ideas?? I think this is a valid argument, don't know why it won't work!
ok here it is another try to justify that my claim in post #2 holds.
Using the mean value theorem we get that:[tex]\exists c\in(0,1)[/tex] such that
[tex]f'(c)=f(1)-f(0)=0[/tex] so now
[tex]f'(x)=(sin\frac{c\pi}{6}- \frac{x}{2})'=\frac{\pi}{6}cos\frac{\pi x}{6}-\frac{1}{2}[/tex]
so
[tex]f'(c)=\frac{\pi}{6}cos\frac{\pi c}{6}-\frac{1}{2}=0=>cos\frac{\pi c}{6}=\frac{1}{2}[/tex]
After we solve this we get for c
[tex]c_1=\frac{6}{\pi}arccos\frac{3}{\pi}+2k\pi[/tex] and
[tex]c_2=-\frac{6}{\pi}acrcos\frac{3}{\pi}+2k\pi[/tex]
from here since [tex]c\in(0,1)[/tex] it means that there is only one critical point in the interval (0,1), so it also means that f'(x) changes sign only once in it, if c is actually a local min or max.
Now by second derivative test we see that
[tex]f''(c)<0[/tex] so it means that [tex]c=\frac{6}{\pi}arccos\frac{3}{\pi}[/tex] is a maximum.
so now i think that my claim that f(x)>0 on the interval (0,1) holds.Because say that there would be another point k, on the interval (0,1) such that f(k)=0, then it automatically would mean that there must be another point say m, such that it should be a local min/max on that interva. But this actually contradicts the fact that there is only once critical point, and hence only one local max on the whole interval (0,1). Hence we have the desired result that:
I think this approach should work.
though when solving for c do we not get
c= (6/pi) arccos (1/2) ?
which equals 2 and is therefore not contained in the interval?
Sorry, ignore that last message, I lost a coefficient! lol thank you v v much for your help o:)
