Solve Extraneous Roots: Why Do They Arise?
  • Context: Undergrad
  • Thread starter Thread starter bacon
    Roots
The discussion centers on the emergence of extraneous roots in the equation √x - √[4]{x} - 2 = 0, which simplifies to (x - 16)(x - 1) = 0. The valid solution is 16, while 1 is identified as extraneous upon substitution back into the original equation. The participants conclude that extraneous roots arise due to violations of mathematical operations, particularly when transitioning between forms of the equation, such as squaring, which can introduce invalid solutions.
  • Understanding of square roots and fourth roots
  • Familiarity with polynomial equations and factoring
  • Knowledge of the order of operations in algebra
  • Basic skills in solving equations and verifying solutions
  • Study the concept of extraneous solutions in algebraic equations
  • Learn about the implications of squaring both sides of an equation
  • Explore techniques for verifying solutions in radical equations
  • Investigate the properties of square roots and their restrictions
Students, educators, and mathematicians interested in understanding the intricacies of solving radical equations and the nature of extraneous roots in algebra.
bacon
Sorry for the length of the post, the problem I've included is not difficult but I wanted to have an example to help illustrate my question.
solve:
[tex]\sqrt{x}-\sqrt[4]{x} -2=0[/tex]
[tex](x-16)(x-1)=0[/tex]
The roots are 16 and 1, however when one puts them back into the original equation, 1 is found to be extraneous leaving 16 as the only solution. My question is, why do extraneous roots arise?
I attempted to answer the question myself by reversing the above process and putting 1 in for x at each step to see when the equation becomes "invalid" for the extraneous root.
[tex]x^{2}-17x+16=0[/tex]
[tex]x^{2}-17x+16+25x=25x[/tex]
[tex]x^{2}+8x+16=25x[/tex]
[tex](x+4)^{2}=25x[/tex]
[tex]x+4=5\sqrt{x}[/tex]
[tex]x+4-4\sqrt{x}=5\sqrt{x}-4\sqrt{x}[/tex]
[tex]x+4-4\sqrt{x}=\sqrt{x}[/tex]
[tex](\sqrt{x}-2)^{2}=\sqrt{x}[/tex]
[tex](\sqrt{x}-2)^{2}=\sqrt{x}[/tex] equation A
[tex]\sqrt{x}-2=\sqrt[4]{x}[/tex] equation B
[tex]\sqrt{x}-\sqrt[4]{x}-2=0[/tex]
Putting 1 in for x in equation A works but B does not. It seems that going from A to B creates the problem. When one takes the square root of equation A the left side becomes
[tex]((\sqrt{x}-2)^{2})^{\frac{1}{2}}[/tex]
If I understood CompuChip's answer correctly to one of my previous posts, the inner to outer priority is not followed. If 1 is in for x, then -1 is the value in the first set of parenthesis and then -1 squared is 1, and then the square root is also 1. However if 1 is not in for x , since the roots are not known when one first goes through the problem, the squared to the 1/2 power gives what's in the parenthesis to the first power, which is just what's in the parenthesis. Then when 1 is in for x, we have -1 to the first power which is -1. The order of operations makes a difference for x=1 but does not for x=16.
Is it true then, that extraneous roots arise because some mathematical operation is violated for that root?
Thanks for any answers.
because equation B is not your original equation, you changed the power, and because of that you changed the roots
[tex]x = 5, x^2= 25, x=5, -5[/tex]. Exactly the same as that, but more disguised =] In this same one, when you squared it, you introduced the erroneous negative square root when only the positive root applies.
  • · Replies 0 ·
  • · Replies 26 ·
  • · Replies 105 ·
13K
