Solving Repeated Eigenvalues - [2,2,1;1,3,1;1,2,2]
  • Thread starter Thread starter hex.halo
    Eigenvalues
The discussion focuses on finding the eigenvalues and corresponding eigenvectors for the matrix [2,2,1;1,3,1;1,2,2]. The eigenvalues identified are 5, 1, and 1, with the eigenvector for the eigenvalue 5 being [1;1;1]. The repeated eigenvalue of 1 leads to a two-dimensional eigenspace, indicating that there are infinitely many eigenvectors associated with this eigenvalue. The solution reveals that the equations derived from the matrix reduce to a single equation, allowing for the selection of arbitrary values for two variables to generate independent eigenvectors.
  • Understanding of eigenvalues and eigenvectors
  • Familiarity with matrix operations and determinants
  • Knowledge of solving linear equations
  • Experience with eigenspaces and their dimensionality
  • Study the concept of eigenspaces in linear algebra
  • Learn how to compute determinants of matrices, specifically 3x3 matrices
  • Explore the method of solving systems of linear equations
  • Investigate the geometric interpretation of eigenvectors and eigenvalues
Students studying linear algebra, mathematicians working on eigenvalue problems, and educators teaching matrix theory will benefit from this discussion.
hex.halo
Obtain the eigenvalues and corrosponding eigenvectors for the matrix: [2,2,1;1,3,1;1,2,2]
I can solve for the eigenvalues, 5, 1, and 1
I can solve the eigenvalue 5 for the eigenvector B[1;1;1]
Yet somehow, the 1 eigenvalues are supposed to give me two different eigenvectors. Unfortunately, this makes no sense to me, which is why I'm here...
Can someone please explain to me how to finish solving this question?
Since 1 is an eigenvaue, the equation
[tex]\left[\begin{array}{ccc}2 & 2 & 1\\1 & 3 & 1\\ 1 & 2 & 2\end{array}\right]\left[\begin{array}{c} x \\ y \\ z\end{array}\right]= \left[\begin{array}{c}x \\ y \\ z\end{array}\right][/tex]
must have a non-trivial solution. Multiplying that out and looking at individual rows, we must have 2x+ 2y+ z= x, x+ 3y+ z= y, x+ 2y+ 2z= z. Because 1 is an eigenvalue, those are not independent and must have an infinite number of solutions. In fact, in this particular problem, the three equations those reduce to, x+ 2y+ z= 0, x+ 2y+ z= 0, and x+ 2y+ z= 0, are all the same equation. You can solve for z as a function of x and y: z= -x- 2y. That means you can choose any numbers you like for x and y, then solve for z to get an eigenvalue. Can you choose them so that you get two independent vectors? (I always like to use simple numbers like 0 and 1.)
I call your matrix B. Then I presume you solved [itex]\det(B-\lambda\mathbb{I}_{3\times 3})=0[/itex] to find the eigenvalues [itex]\lambda[/itex]. You found [itex]\lambda_1=5 \text{ and } \lambda_2=1[/itex].
Once you have done that I further assume you tried to find the eigenvector [itex]v_i[/itex] associated to the eigenvector [itex]\lambda_i[/itex] by solving [itex](B-\lambda_i\mathbb{I}_{3\times 3})v_i=0[/itex]. For your eigenvalue one you will find that this equation leads to a two-dimensional solution space for [itex]v_2[/itex], the so called eigenspace. ANY vector in this two-dimensional space will be an eigenvector with eigenvalue one.
  • · Replies 19 ·
