What Determines the State of Matter of Elements at STP?
  • Thread starter Thread starter gateman234
    Gases Noble gases
The state of matter of elements at standard temperature and pressure (STP) is primarily determined by intermolecular forces, particularly van der Waals forces. Noble gases, such as argon, exist as gases due to their full outer electron shells, which result in weak intermolecular attractions. In contrast, elements like sulfur, which seek to complete their outer shells, exhibit stronger attractions and can exist as solids or liquids. Understanding these concepts is crucial for grasping the behavior of different elements under normal atmospheric conditions.
  • Understanding of intermolecular forces, specifically van der Waals forces
  • Familiarity with electron shell configuration and its implications
  • Basic knowledge of gas laws and their applications
  • Concept of standard temperature and pressure (STP)
  • Research the different types of intermolecular forces, including dipole-dipole interactions and hydrogen bonding
  • Study the properties of noble gases and their behavior under various conditions
  • Explore the relationship between atomic structure and state of matter
  • Learn about gas laws and how they apply to real-world scenarios
Chemistry students, educators, and anyone interested in understanding the physical properties of elements and their states at STP.
gateman234
[SOLVED] why are noble gases, gases?
this has bothered me for some time,
what determines the density of an element at normal atmoshpheric conditions?
and more importantly what determines if a substance at s.t.p is a gas solid or liquid
gas laws, maybe?
i was thinking there might be some repulsion and atractions between atoms, like with Ar it contains a full outer shell which means to gain more electrons it would require a new level which would take a lot of energy, compared to Sulfur which is trying to complete a full outer shell, which reqiures less energy. so there is more atractration between atoms.
this only can aply for some atoms, help?
have you done anything on the different types of intermolecular force yet? If so, you will easily realize partly why the noble gases are, in fact, gases. The "density" of an element is a bit of a funny thing to be talking about, because in gas terms we generally don't talk about density in the same way (we don't say there is so many kg/m^3 of argon, we say there are so many ppm or ppb.
Looking at your posts so far it seems you have phrased everything only in terms of electron shells. Admittedly I find that just about all chemistry (apart from physical chemistry) can be explained by electron shells (hence why I'm more of a physicist), but maybe you should wait a little while and things will become clearer to you.
In argon, and indeed any element you have only weak van der waals forces between particles, so that's why most of the non-metals are in fact gases, until you get up to really heavy stuff.
Attraction and repulsion between atoms has absolutely nothing to do with how hard they are "trying to complete a shell". If you want to understand more, look up intermolecular forces and how they work. It should be very soon part of your chemistry course.
And finally, re your other post, this should definitely be in the chemistry subforum.
ok, thanks for your time.
  • · Replies 35 ·
  • · Replies 49 ·
9K
