Photo voltaic cell Vs. solar heating panel
This discussion focuses on comparing the efficiency of photovoltaic cells and solar heating panels when exposed to a 150W bulb. The key equations referenced are P=IV for photovoltaic cells and P=fcT for solar heating panels, where 'f' is flow rate, 'c' is specific heat capacity, and 'T' is the change in temperature. Participants emphasize the importance of using the total area available for installation rather than just the exposed surface area of the pipes. Additionally, they note that using a tungsten light bulb is not an ideal substitute for sunlight due to its lack of shorter wavelength light.
  • Understanding of photovoltaic cell efficiency metrics
  • Knowledge of solar heating panel operation and equations
  • Familiarity with basic physics concepts such as power (P), current (I), and voltage (V)
  • Awareness of the differences between artificial light sources and sunlight
  • Research the efficiency ratings of different photovoltaic cells
  • Study the thermal dynamics involved in solar heating panels
  • Explore the impact of light wavelength on solar energy absorption
  • Investigate real-world performance comparisons between photovoltaic cells and solar heating panels
Students studying renewable energy technologies, engineers involved in solar energy projects, and researchers comparing solar energy conversion methods.
oprfot
i've been asked to compare the efficiency of a photo voltaic cell and a solar heating cell (an array of pipes). both will be exposed to a 150W bulb for an equal amount of time.
for photo cell: P=IV
for heating panel: P=fcT f=flow rate c=specific heat capacity T=change in temp
im trying to say that both will have the same surface area exposed to the light, i was just wondering what measurement to use for the pipes: the surface area of the pipes that is exposed, or the area of the whole panel??
any other suggestions would be welcome :D
I wouldn't worry about the actual surface area of the pipe. You are comparing a practical installation so the only consideration is the total floor (or roof!) area available for installation.
Using a tugsten light bulb isn't a good model for the sun, it lacks the shorter wavelength blue and UV light that the solar panel is sensitive to.
Can't you put both outside at the same time pointing in the same direction?
That would also allow you to compare their relative efficency at best - sun pointing directly at them, vs worst - sun on horizon.
yeah, i guess youre right, if I am comparing the panels i should just use the area.
we've been told to use a lightbulb, i know the actual sun would deliver a more useful result, but the bulb is what we're given.
now that I am thinking about it, I am not quite sure what to use as the independent variable. would the different panels be enough?
