Double differentials and some curious problems
  • Context: Graduate
  • Thread starter Thread starter Ultimâ
    Curious Differentials
The discussion revolves around the differentiation of angular rates and the construction of a Jacobian matrix related to these derivatives. Participants explore various mathematical expressions involving double differentials and their implications in the context of angular motion, particularly in relation to an Extended Kalman Filter (EKF).
  • One participant presents a differentiation problem involving \(\dot{\theta}\) and suggests the result may be zero, although they express uncertainty about their reasoning.
  • Another participant questions the meaning of \(\Delta p\) and \(\Delta t\) in the context of the differentiation and suggests that \(\theta\) and \(\dot{\theta}\) might need to be treated as independent variables.
  • There is a proposal to apply the product rule for differentiation in one of the expressions, indicating a potential oversight in the original approach.
  • Several participants express confusion about the context and the specific mathematical operations being performed, particularly regarding the Jacobian matrix and its elements.
  • One participant suggests that if the total derivative of \(\dot{\theta}\) with respect to \(\theta\) is zero, it implies that \(\dot{\theta}\) is constant, leading to a linear relationship for \(\theta(t)\), though they acknowledge this may not hold in general cases.
  • Another participant emphasizes the importance of not simplifying the derivatives too early in the process, especially when certain variables are not available for direct calculation.
  • There is a mention of the need to evaluate the Jacobian at a specific point and the potential issues with inverting the function \(\theta(t)\).
Participants express various viewpoints and uncertainties regarding the differentiation methods and the implications of their results. There is no clear consensus on the correctness of the approaches or the interpretations of the results.
Participants note limitations in their understanding of the context, particularly regarding the application of the Jacobian in the EKF and the treatment of variables as independent or dependent.
This discussion may be of interest to those working on problems involving angular motion, Jacobian matrices, or the implementation of Extended Kalman Filters in their analyses.
Ultimâ
Hello, I'm toying around with a Jacobian that has raised some interesting problems. It's a case of differentiating rates of some variable x, with respect to itself.
First one I suspect the answer is zero, though perhaps my reasoning is a bit flawed.
1.
[tex] \frac{d}{d\theta}(\dot{\theta})<br /> =\frac{d \dot{\theta}}{dt} \times \frac{dt}{d\theta}<br /> =\ddot{\theta} \times \dot{\theta}^{-1}<br /> =\ddot{\theta} / \dot{\theta}<br /> =\frac{\Delta p }{\Delta t}}/\Delta p<br /> =\Delta t \approx 0[/tex]
The second I think you apply the total derivative rule to, but maybe not, should the angle and angle-rate be considered as two separate variables?
2.
[tex] \frac{d}{d\theta}(\dot{\theta}cos\theta)<br /> =\frac{dF}{d\theta}<br /> =\frac{\partial F}{\partial \dot{\theta}} \times \frac{d\theta}{dt} +<br /> \frac{\partial F}{\partial \theta} \times \ddot{\theta}<br /> =\dot{\theta}cos\theta - \ddot{\theta}\dot{\theta}sin\theta[/tex]
Last one has me flummaxed...
3.
[tex] \frac{d}{d\theta}(\theta+\dot{\theta}dt)=?[/tex]
And finally
4.
[tex] \frac{d}{d\dot{\theta}}(q sin\phi tan\theta + r cos\phi tan\theta)<br /> =\frac{1}{\ddot{\theta}}\times \frac{d}{dt}(q(t) sin\phi (t) tan\theta (t)+ r (t) cos\phi (t) tan\theta (t))<br /> =?[/tex]
Number 4 I arrive at from the chain rule (an example below):
[tex] \frac{dy}{d\dot{\theta}}=\frac{dy}{dt} \times \frac{dt}{d\dot{\theta}}<br /> =\frac{dy}{dt} \times \left(\frac{d\dot{\theta}}{dt}\right)^{-1}<br /> =\frac{\dot{y}}{\ddot{\theta}}[/tex]
Could anyone confirm what I've done so far (or point out any mistakes)? Cheers.
Just to clarify, 3. slightly, the [tex]dt[/tex] is actually the sample period, so [tex]\dot{\theta}dt\approx \Delta\theta[/tex], but I'm unsure how this affects the derivative...
Also, in 2. maybe I should use the product rule, but I think the term you are using for differentiating needs to be different...
(product rule)
[tex] \frac{d}{dz}(xy)= x\frac{dy}{dz}+y\frac{dx}{dz}[/tex]
Ultimâ said:
1.[tex]\frac{d}{d\theta}(\dot{\theta})<br /> =\frac{d \dot{\theta}}{dt} \times \frac{dt}{d\theta}<br /> =\ddot{\theta} \times \dot{\theta}^{-1}<br /> =\ddot{\theta} / \dot{\theta}<br /> =\frac{\Delta p }{\Delta t}}/\Delta p<br /> =\Delta t \approx 0[/tex]
Hi Ultimâ! :smile:
I'm confused … what are ∆p and ∆t?
And what is the context that this is a part of? Is it something like a Lagrangian, where θ and θ' are treated as independent variables, so that ∂θ'/∂θ = ∂θ/∂θ' = 0 anyway?
If not, I don't understand how you get from θ''/θ' to (∆p/∆t)/∆p. :confused:
Sorry! I just jumped into a shorthand replace with the following:
[tex] \frac{\Delta p }{\Delta t}}/\Delta p<br /> =\frac{\Delta \dot{\theta} }{\Delta t}}/\Delta \ddot{\theta}[/tex]
The context is trying to create a Jacobian matrix to estimate the covariance for angular rates. I don't really want to delve into to much detail as the matrix is rather large, but in a simplified form:
[tex] \mathbf{x}_{k|k-1}=\mathbf{A}_k\mathbf{x}_{k-1|k-1}[/tex]
and I need to find
[tex] \mathbf{J}_k=\frac{d(\mathbf{x}_{k|k-1})}{d(\mathbf{A}_k\mathbf{x}_{k-1|k-1})}[/tex]
Thinking about 3. a bit more I believe [tex]1[/tex] would be a fairly accurate approximate.
That is
[tex] \frac{\Delta p }{\Delta t}}/\Delta p<br /> =\frac{\Delta \dot{\theta} }{\Delta t}}/\Delta \dot{\theta}[/tex]
Hi Ultimâ! :smile:
Ultimâ said:
The context is trying to create a Jacobian matrix to estimate the covariance for angular rates. I don't really want to delve into to much detail …
I think you'd better delve a little, as I've really no idea what you're doing.
You seem to be trying to differentiate one element of a matrix with respect to another. :confused:
And does the J in Jk mean Jacobian, or angular momentum?
(btw, the LaTeX for ∂ is \partial … see http://www.physics.udel.edu/~dubois/lshort2e/node61.html#SECTION008100000000000000000 )
For your first one:
[tex]\frac{d}{d\theta}(\dot{\theta})=\frac{d \dot{\theta}}{dt} \times \frac{dt}{d\theta}=\ddot{\theta} \times \dot{\theta}^{-1}=\ddot{\theta} / \dot{\theta}= \frac{d}{dt}\ln \dot{\theta}[/tex]
If that total derivative is equal to zero, then it means you must have [itex]\ln \dot{\theta} = \mbox{const}[/itex], which means [itex]\dot{\theta} = \mbox{const}[/itex], which means [itex]\theta(t) = a + bt[/itex], which won't be the case in general. The reason it's not zero in general is that for general cases you can in principle invert [itex]\theta(t)[/itex] to get [itex]t(\theta)[/itex], and so one could then write[itex]\ddot{\theta}(t) = \ddot{\theta}(t(\theta)) = \ddot{\theta}(\theta)[/itex].
Mute said:
For your first one:
Actually, I didn't even need to do the bit with the ln. From the very first term, if [itex]d\dot{\theta}/d\theta[/itex] is zero, then [itex]\dot{\theta} = \mbox{const}[/itex] and [itex]\theta = a + bt[/itex].
tiny-tim - Sorry if I didn't make things very clear, but I was just hoping people could check what I had done seemed reasonable - that is simplifying the derivatives in 1.->4. These happen to be four of the elements of J (yes it is a Jacobian) that I'm inputting as a matrix for an Extended Kalman filter (EKF) I'm working with. This simplification means having things in terms of p q r [tex]\phi \ \theta \ \psi[/tex] or their rates (values of which the EKF has available for making calculations).
I think Mute is suggesting I shouldn't simplify after the fourth part of No. 1, which do-able, though I don't actually have theta_doubledot available and would need to use [tex]\frac{\dot{\theta}_t - \dot{\theta}_{(t-1)}}{dt}[/tex] to estimate this...
This is a little bit guessing, but if you are playing around with jacobian then it is most probably
[tex]\frac{\partial \dot{\theta}}{\partial \theta} = 0[/tex]
and the jacobian is evaluated at some point... Also you cannot always invert the function [itex]\theta(t)[/itex] and you don't check if [itex]\frac{dt}{d\theta}[/itex] is invertible...
Well since I was asked for it, here's the full problem I have (see pdf),...Anything wrong with my reasoning here for the elements I have calculated for the Jacobian?
