Heat Exchanger Thermal Calculations
The discussion focuses on the thermal calculations for heat exchangers, specifically using the heat balance formula for a condenser involving steam and water. The key formula presented is Qadded = Qrej, expressed as mdot(cw)*Cpw*(Tout-Tin) = Mdot(st)*hst. Here, mdot represents mass flow rate, Cp denotes specific heat of water at constant pressure, T indicates temperature, and h signifies the enthalpy of saturated steam. Understanding these components is essential for accurate thermal analysis in heat exchangers.
  • Understanding of heat exchanger principles
  • Familiarity with thermodynamic properties of fluids
  • Knowledge of mass flow rate calculations
  • Basic grasp of enthalpy and specific heat concepts
  • Research the design and operation of condensers in heat exchangers
  • Study the impact of fluid properties on heat transfer efficiency
  • Learn about advanced heat exchanger modeling techniques
  • Explore software tools for thermal analysis, such as HTRI or Aspen Plus
Engineers, thermal analysts, and students in mechanical or chemical engineering fields who are involved in the design and analysis of heat exchangers.
elec2050
Hello,
Can anyone get me Heat exchanger thermal formula and equations
Tom
There's a lot more to understanding heat exchangers than a few formulas...
what type of the two fluids used in this heat exchanger?
the most imp formula which is used with the exchangers its doing the heat balance for these two fluids,lets say its a condenser,
so the two fluids are the steam and the water,
the formula used:
heat added to the water(Qadded)=the heat rejected by the steam(Qrej)
mdot(cw)*Cpw*(Tout-Tin)=Mdot(st)*hst
where:Mdot is:mass flow rate,Cp is:specific heat of water at constant pressure,T is:temperature&h is:the enthalpy of a saturated steam.
generally,its doing a heat balance for the two fluids using in the heat exchanger by the same way with the condenser.
let me know if i missed something with what I've mentioned,
thanks for the forum.
  • · Replies 21 ·
  • · Replies 34 ·
