Calculating Spring Force for Fluid Control Regulator
The discussion focuses on calculating the spring force required for a back pressure regulator in fluid control applications. To exceed a back pressure of 3 bar (300,000 N/m²) and open the ball valve, a force of approximately 93 Newtons is necessary, based on the inlet bore diameter of 2 mm and its area of about 3.1 mm². The flow rate of 82 mls/min is deemed irrelevant to the spring force calculation. Key considerations include applying a freebody diagram to the sensing element and accounting for the poppet area, which significantly impacts the spring load and valve performance.
  • Understanding of fluid dynamics principles
  • Familiarity with back pressure regulators and their components
  • Knowledge of freebody diagram analysis
  • Experience with calculating flow using Cv (flow coefficient)
  • Research the principles of back pressure regulation in fluid systems
  • Learn how to apply freebody diagrams in mechanical design
  • Study the calculation of flow rates using Cv for various valve types
  • Explore the effects of spring load on cracking pressure and valve lift
Engineers and designers working on fluid control systems, particularly those involved in the design and optimization of back pressure regulators and related components.
mkelly
I need to calculate the spring force required to make a back pressure regulator for fluid control the back pressure must exceed 3bar to open the ball valve the flow rate is 82mls/per min. the bore dia of the inlet is 2 mm dia. any help greatly appreciated
3 bar is 300000 N/m2 and your bore has an area of approximately 3.1 mm2= .00031 m2 so you are talking about a force of approximately 93 Newtons. The flow rate is irrelevant.
Apply a freebody diagram to your sensing element, including poppet and spring. Diaphragm element area can be estimated by using the average diameter of backing plate diam and clamped diam at body. Don't forget to include poppet area as this is generally significant. Spring load then determines cracking pressure and 'droop'. You need to then determine valve lift above cracking pressure which produces a flow. Is that what you need? Are you familiar with calculating flow from Cv?
  • · Replies 35 ·
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 51 ·
38K
