Halliday and Resnick - Boy sliding down ice mound
The discussion centers on a physics problem involving a boy sliding down a frictionless hemispherical ice mound. The key focus is on determining the height at which the boy loses contact with the ice, using principles of conservation of mechanical energy and Newton's second law. Initial calculations suggest that the boy's potential energy at the top converts to kinetic energy at the bottom, leading to a derived speed. The critical point of analysis is when the normal force equals zero, indicating loss of contact, which requires considering only the radial component of gravitational force for centripetal acceleration. The final calculated height at which the boy loses contact is approximately 6.9 meters.
Farnak
This is from Fundamentals of Physics 8th ed, by Halliday and Resnick:
A boy is initially seated on the top of a hemispherical ice mound of radius R = 13.8m. He begins to slide down the ice, with a negligible initial speed. Approximate the ice as being frictionless. At what height does the boy lose contact with the ice?
This is classified under Conservation of Mechanical Energy
There's a picture of a semicircle and a boy sliding down the circumference of the semicircle.
I don't understand what conditions would make the boy go off the ice rather than stay on the ice. I thought it had to do with centripetal forces at first (cause he's going in a circle ... for a bit) but I couldn't make that idea work.
Try it again--that's the right track. Apply Newton's 2nd law. And conservation of energy.
So far what I did was
PEtop= KE bottom
mgh=.5mv^2
gh=.5v^2
(9.81)h=(0.5)v^2
then at the point where the boy just barely stays on the ice mound, I used the equation
Fn= Fw-Fc, which would be 0 at that point
0=mg-(mv^2/r)
mg=(mv^2/r)
g=v^2/r
gr=v^2
(9.81)(13.8)=v^2
v^2= 135.378 m/s
Plug that v^2 back into the initial equation:
(9.81)h= (0.5)(135.378)
h= 6.9m
Does that look right?
Likes Israt afroz
It's true that the normal force will be zero at that point, but only a component of the weight contributes to the centripetal force. Not the full mg, which acts downward. (Find the radial component.)
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
