Conduction what if questions
  • Thread starter Thread starter engineer23
    Conduction
The discussion focuses on the implications of using the lumped capacitance method in heat conduction analysis when the Biot number (Bi) exceeds 0.1. It establishes that a Biot number greater than 1 indicates significant temperature gradients within the solid, rendering the lumped capacitance method an inaccurate approximation. Consequently, this leads to a non-uniform temperature distribution and an extended time to reach steady state, contradicting the assumptions made in calculations based on the lumped capacitance method.
  • Understanding of the Biot number (Bi = hL/k)
  • Familiarity with the lumped capacitance method in thermal analysis
  • Knowledge of transient heat conduction principles
  • Concept of temperature gradients in solids and fluids
  • Research the implications of Biot number in heat transfer analysis
  • Study the limitations of the lumped capacitance method
  • Learn about non-homogeneous temperature distributions in solids
  • Explore transient heat conduction and its mathematical modeling
Engineers, thermal analysts, and students in mechanical or materials engineering who are involved in heat transfer analysis and require a deeper understanding of conduction principles and methods.
engineer23
Conduction "what if" questions...
What is the Biot number (hL/k) is greater than 0.1 and I use the lumped capacitance method for analysis (i.e. there are temperature gradients in the "lump" and I have assumed they are absent). What effect does it have on the result?
What is the largest number of non-homogeneities that can exist in a conduction solution?
The Biot number is used to determine if the lumped capacitance method is a valid approximation of a transient problem that involves convection about a solid. When the Biot number is much less than 1, the resistance to conductive heat transfer within the solid is much less than the resistance to convective heat transfer across the fluid boundary layer.
Put another way, if the Biot number is much less than 1 then the temperature gradient across the solid is much less than the temperature gradient across the fluid boundary layer. Given two temperature gradients, if one is much larger than the other then the smaller one can be assumed to have a negligeble effect on the system, and so it may be disregarded.
To answer your question, if you use the lumped capacitance method for a system where the biot number is close to or higher than one, the solid your are analyzing will have a non-uniform temperature distribution in it. So if this is the case, the system will take longer to reach steady state than your calculation implies.
13K
