How can I measure lift in a wind tunnel?
The discussion revolves around measuring lift in a wind tunnel, particularly in the context of researching how aircraft wing design affects lift. Participants explore methods for constructing a wind tunnel and measuring lift forces, while considering various factors that influence aerodynamic performance.
  • Experimental/applied
  • One participant suggests using scales to measure forces and discusses the need to rig the model to hold its position while measuring forces and torques.
  • Another participant proposes using hooks to attach the model in the wind tunnel and questions how scales would be integrated into this setup.
  • There is a discussion about the design of airfoils, noting that glider wings are optimized for lift-to-drag ratios and that larger wingspans can achieve higher ratios.
  • Concerns are raised about the effects of wind tunnel size and speed on airflow, with references to laminar flow and Reynolds number considerations.
  • One participant inquires about the appropriate velocity for high-speed testing and mentions the potential use of low-viscosity gases to simulate higher speeds in wind tunnels.
  • Another participant emphasizes the importance of understanding the specific model's size and expected speed range when determining testing parameters.
  • There is a suggestion to research existing university wind tunnels for insights on instrumentation and force measurement techniques.
Participants express various methods and considerations for measuring lift, but no consensus is reached on a specific approach or the best practices for wind tunnel design and operation. Multiple competing views on instrumentation and testing conditions remain present.
Participants mention limitations related to wind tunnel size, speed, and airflow characteristics, as well as the dependence on specific model designs and testing conditions. The discussion reflects a range of assumptions and uncertainties regarding the measurement techniques and aerodynamic principles involved.
jozef
Aerodynamics -- Wind tunnel
I'm not sure if this goes under here since it's not actually homework but it's more of a general question for a paper I have to do, so if it's in the wrong place I apologize; simply tell me and I'll delete it or something.
Okay well for my research paper I'm thinking of doing how the design of aircraft wings affect lift. I'm planning on constructing a simple wind tunnel but assuming I get everything else to work, I'm not exactly sure how to measure lift inside the wind tunnel. If someone could be of help, it would greatly be appreciated. Thanks.
Some type of scales to measure the forces are normally used. You'll need to figure out some method of rigging the model or wing in order to hold it's position while being able to measure the forces and torques.
Normally the design of an airfoil is to optimize for it's intended use while compromising for the sake of production costs. Most powered aircraft operate well above best lift to drag ratio speed for the wings they use, but here the focus is a reasonable (within cost constraints) miminal amount of drag while producing enough lift for level flight at cruise speed.
Glider wing design, both full scale and models focus on lift to drag ratios at an intended range of speeds, but there's a limit as to what airfoils can accomplish, and large wingspans are the way to achieve very high lift to drag ratios; high end gliders with over 80 foot wing spans have 60:1 glide ratios. Most glider airfoils are thinned and cambered tear drop shapes.
Another issue is the wind tunnel itself. Low speeds result in more laminar airflow than higher speeds, and there is a Reynolds number factor also at play. Short (vertical) wind tunnels restrict vertical component of air flow affecting the outcome. The best wind tunnels are large (compared to model size) and relatively high speed. An alternative for high speed air tunnel is to a gas with low viscosity, to keep the Reynold factor about the same as the intended model.
For this, I thought about having hooks on either end of the wind tunnel and then tying it to the plane and then having the fan start up so the plane would receive a tailwind and I could measure the lift in the plane. However, I'm not sure as to where the scales come into play if I were to use the hooks.
Edit: I was going through some of the other posts and I was wondering if a spring scale would work to measure lift.
For the purpose of the experiment, I would only be looking at lift so would I then need to refocus my question to include the drag itself or would it be acceptable to simply focus on just the lift portion of the experiment.
At what velocity would you consider it being high speed as for the gas it might be a possible option for me to do as well but I'll have to ask my supervisor.
Depends on what you're trying to model, mostly the size and expected speed range for the targeted aircraft of the model. There are indoor free flight models that fly at less than 5mph. Small outdoor models range between 10mph to 20mph. Full scale gliders range from 45mph to 70mph (for best lift to drag ratio speed). Powered aircraft fly faster still.
I'd recommend a web search on existing wind tunnels at universities, to get an idea of how they "instrument" (hook up force measuring devices) on their models. I'm not sure how this is done myself. Regarding Reynolds factor at low speeds, if I remember correctly, helium is a low viscosity gas used at slower speed to emulate air at higher speeds in wind tunnels, but you need a closed system type wind tunnel to use it.
  • · Replies 17 ·
  • · Replies 30 ·
