How Do You Calculate the Original Velocity of a Cannonball in a Collision?
  • Thread starter Thread starter sweedeljoseph
    Velocity
The discussion centers on calculating the original velocity of a 30 kg cannonball that collides with a stationary 150 kg wooden block, resulting in both moving together at 4 m/s. The correct approach utilizes the conservation of momentum formula, represented as m1v1 + m2v2 = (m1 + m2)v'. The original velocity of the cannonball is determined to be 24 m/s, confirming the teacher's answer. The misunderstanding arose from the interpretation of the final velocity post-collision.
  • Understanding of conservation of momentum principles
  • Familiarity with basic algebraic manipulation
  • Knowledge of mass and velocity units (kg and m/s)
  • Ability to set up and solve equations
  • Study the conservation of momentum in elastic and inelastic collisions
  • Learn how to derive equations for two-body collisions
  • Explore real-world applications of momentum in physics
  • Practice problems involving momentum calculations with varying masses and velocities
Students studying physics, particularly those focusing on mechanics and collision problems, as well as educators looking for clear explanations of momentum concepts.
sweedeljoseph
A 30 kg cannonball strikes a 150 kg stationary wooden block and embeds itself in the block. The block and cannonball move together at 4 m/s. What was the original velocity of the cannonball?
m1v1=m2v2
using the equation i gave i got:
30v=150(4)
v=20
the answer my teacher my teacher gave me was 24 m/s. and i was thinking if you add the '4 m/s' to the velocity i just found it would be '24 m/s'. but i don't know if that was right. i was thinking it might be right because they both moved together after the ball hit the wood for 4 m/s. so is that right? or am i supposed to do something else?
thank you!
sweedeljoseph
The mass after the collision would be the masses of both objects added together since they are now considered to be one object moving at the same velocity.
m1V1 + m2V2 (equals 0) = v'(m1 + m2)
Solve for V1 before
so i was right? you add the '4 m/s' to the velocity that i found?
22K
