Proving Linear Independence of Basis for Vector Space - How to Finish the Proof?
The discussion revolves around proving that a set of linear transformations {f_1,...,f_n} forms a basis for the dual space V* of a vector space V, given that {v_1,...,v_n} is a basis for V. Participants explore the properties of linear independence and spanning sets in the context of vector spaces and their duals.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to use properties of dimensions and linear transformations to establish a basis for V*. They express uncertainty about proving linear independence and spanning properties without explicit matrix forms.
  • Some participants suggest focusing on the definitions of the transformations and their evaluations at basis vectors to demonstrate spanning and linear independence.
  • Questions arise regarding how to evaluate f(v_1) and the implications of the relationships between the transformations and the basis vectors.
Participants are actively engaging with the problem, offering insights and clarifications. Some have made progress in understanding the linear independence of the transformations, while others are still working through the implications of spanning. There is a collaborative effort to refine the arguments and clarify the relationships between the elements of V and V*.
Participants note the challenge of dealing with abstract concepts such as functions and matrices in the context of vector spaces, which may complicate the proof process. The discussion also reflects on the definitions and properties of dual spaces and their dimensions.
Frillth
Let V be a vector space, and suppose {v_1,...,v_n} (all vectors) form a basis for V. Let V* denote the set of all linear transformations from V to R. (I know from previous work that V* is a vector space). Define f_i as an element of V* by:
f_i(a_1*v_1 + a_*v_2 + ... +a_n*v_n) = a_i
Prove that {f_1,...,f_n} gives a basis for V*.
A basis of a subspace is a set of vectors that are linearly independent and span the subspace.
By a theorem from my book, I know that for two subspaces V and W, dim V = dim W implies V = W. Since the basis for V has n vectors, dim(V) = n. Also, dim(R^n) = n. Thus, V can be equated with R^n. Since all vectors in V are in R^n, any linear transformation from V to R must have a corresponding 1xn matrix, so we know that f_1 through f_n have corresponding 1xn matrices. Since we can take the transpose of these matrices to form vectors in R^n, we can easily equate V* to R^n, so dim V* = n. This is another theorem from the book:
Let V be any k-dimensional subspace in R^n. Then any k vectors that span V must be linearly independent and any k linearly independent vectors in V must span V.
Now to finish up, I need to show that either {f_1,...,f_n} span V or they are linearly independent. I'm having trouble with either of those, though, since I don't have an explicit matrix form for any of the functions. All I know is that f_i gives the ith coordinate of a vector in V. I can prove linear independence by showing that:
c_1*[f_1] + c_2*[f_2] + ... + c_n*[f_n] = [0] implies c_1 = c_2 = ... = c_n = 0.
All I can think of from here is to multiply both sides by (a_1*v_1 + a_*v_2 + ... +a_n*v_n) to get:
c_1*a_1 + c_2*a_2 + ... + c_n*a_n = 0.
But I think I must have made an error somewhere, because we can easily show that that equation does not imply that c_1 = ... = c_n = 0.Can somebody please point me in the right direction?
Also, have I made any errors in my proof so far?
Thanks.
You can think about this a lot more directly, without dragging matrices into it. You want to show if f is any element of V* then you can express it as a sum of the f_i, right? Consider the constants f(v_i)=a_i. Can you think of a way to use those to express f as a sum of the f_i? Remember if two elements of V* have the same value for all of the basis vectors, they have the same value for any vector. That shows they span. Now suppose the sum of c_i*f_i=f=0. Can you show that that implies that all of the c_i are zero? What for example is f(v_1)? That would show they are linearly independent.
How do I determine what f(v_1) is if all I know about f is that it takes v_1 from V to R?
I said, suppose f=sum c_i*f_i. Then what is f(v_1)? Of course you can't say much if f is ANYTHING.
OK, I think I got it. We have f(v_i) = c_i, so if we take the equation c_1*f_1 + c_2*f_2 + ... + c_n*f_n = 0 and we multiply by c_i, we get c_i = 0, thus implying that {f_1,...,f_n} is linearly independent.
I'm having trouble with your proof that they span, though. When you said "f(v_i)=a_i" did you mean to write "f_i(a_i*v_i) = a_i"?
Ah, never mind. I figured it out. Thank you very much for your help.
I have one more related problem:
Assume that V is a finite-dimensional vector space, and V* is defined as above. Prove that dim V = dim V*.
I know that I can prove this if V is defined as in the previous problem, but I'm getting tripped up by the fact that a vector space can contain things like functions and matrices.
You've shown that if v_i is a basis of V, then f_i is a basis of V*, right? There's the same number of v's as f's isn't there?
Oh, that is much simpler than I was trying to make it. Thank you very much for your help.
  • · Replies 17 ·
