Calculate lattice constant from x-rays
The discussion focuses on calculating the lattice constant of NaCl using X-ray diffraction data. The angle of constructive interference is given as 16.3 degrees, and the frequency of the X-ray is 1.948 x 1018 Hz. The relevant equations include 2d * Sin(Theta) = m * Lambda and d = a/sqrt(h2+k2+l2). The participant struggles with determining the Miller indices (h, k, l) necessary for calculating the lattice constant, which is expected to be between 5.63-5.65 Å.
  • Understanding of X-ray diffraction principles
  • Familiarity with Miller indices in crystallography
  • Knowledge of solid-state physics concepts
  • Proficiency in using the equation 2d * Sin(Theta) = m * Lambda
  • Research how to determine Miller indices for cubic crystals
  • Study the relationship between wavelength and lattice parameters in X-ray diffraction
  • Learn about the Bragg's Law and its applications in crystallography
  • Explore the use of X-ray diffraction software for lattice constant calculations
Students in solid-state physics, crystallographers, and anyone involved in materials science seeking to understand lattice constant calculations through X-ray diffraction techniques.
tibsy
When x-rays are diffracted off NaCl, constructive interference is observed at an angle of 16.3 degrees. Determine the lattice constant of NaCl.
Frequency of the X-ray is 1.948 x 10^18 hz
Theta = 16.3 degrees
(As far as what we're told to use and what's in the book)
2d * Sin (Theta) = m * Lambda
After looking through the problem it is very clear that I am unable to find the "lattice constant" from the information given in the book.
I've found the following equations:
1) d = a/sqrt(h2+k2+l2)
2) Lambda/2a= sin 2 Theta/h2+k2+l2
I've tried deriving #2 down to where it is usable and I get:
a2 = (Lambda2/4) * (h2+k2+l2/Sin2 Theta)
I've been unable to figure out what the miller indices are (h k and l), but everything I've tried doesn't get anywhere near the values expected online of 5.63-5.65.
Am I going about this completely wrong or am I just overthinking the problem?
Any help would be much appreciated.
I don't think you can figure out the Miller indices if you don't know the orientation of the crystal anyway, right? (It's been a while since I took solid state.)
EDIT: I don't get 5.63 (Angstoms?) either (for any value of m).
9K
11K
