Transmittance of absorbing multilayer thin-films on an absorbing substrate
  • Context: Graduate
  • Thread starter Thread starter DivGradCurl
    Substrate
The discussion revolves around the calculation of transmittance (T) for multilayer thin-film stacks situated on an absorbing substrate. Participants explore theoretical expressions and methodologies for determining transmittance, particularly in the context of complex media and oblique incidence. The scope includes theoretical derivations and comparisons of different references in optics.
  • One participant references a general expression for amplitude transmittance (t) but notes a lack of clarity on deriving transmittance (T) for multilayer films on an absorbing substrate.
  • Another participant suggests that the transmittance might simply be zero due to the assumption of a semi-infinite absorbing substrate.
  • A different participant proposes a generalized expression for transmittance, incorporating decay due to absorption, and cites a reference that discusses the Lambert law of absorption.
  • Another participant finds a different expression for transmittance in multilayer stacks and questions the differences in the treatment of TE and TM polarization, noting inconsistencies with cited references.
Participants express various hypotheses and approaches regarding the calculation of transmittance, with no consensus reached on the correct method or expression. Disagreements arise over the treatment of different polarizations and the implications of using complex refractive indices.
Participants highlight potential limitations in the assumptions made, such as the semi-infinite nature of the substrate and the treatment of complex refractive indices. There are also unresolved questions regarding the mathematical steps involved in deriving transmittance expressions.
DivGradCurl
I have found a general expression for the amplitude transmittance [tex](t)[/tex] of multilayer film stacks in the literature [1], but the author does not explain how to obtain the transmittance [tex](T)[/tex]. I looked up other references, and the closest I could find was the description of "an absorbing film on a transparent substrate" [2].
On page 756 of [2] there are expressions for transmittance:
[tex]T = \frac{n_3 \cos \theta _3}{n_1 \cos \theta _1} \left| t \right| ^2 \qquad \qquad \mbox{(TE)}[/tex]
[tex]T = \frac{(\cos \theta _3) / n_3}{(\cos \theta _1)/ n_1} \left| t \right| ^2 \qquad \qquad \mbox{(TM)}[/tex]
In other words, I'm trying to find the transmittance (using the amplitude transmittance value I already know) for a system that consists of a semi-infinite incidence medium (dielectric), many thin-films (absorbing), and a semi-infinite substrate (absorbing). In comparison, the reflectance is easy to find, because you just multiply the reflectivity by its complex conjugate; this is not the case. If you use the expressions above, replacing [tex](n_3)[/tex] and [tex](\theta_3)[/tex] by the substrate complex refractive index and the complex angle on the exit side, respectively, the results will be complex as well.
Any ideas? Thanks.
[1] J. Eastman, Surface scattering in optical interference coatings. PhD thesis, University of Rochester, 1974.
[2] M. Born and E. Wolf, Principles of Optics. Cambridge, UK: Cambridge University Press, 7th ed., 1999.
Science news on Phys.org
PS: maybe it's simply 0, because of my semi-infinite assumption for an absorbing substrate.
I've found an explanation in this reference [3]. This is not exactly what is in the book, but it's what I think is correct. Please correct me if I am wrong.
In a system where the media are:
# 0 = a semi-infinite dielectric (transparent incident medium)
# 1 = the first thin film (absorbing)
# m = the last thin film (absorbing)
# m+1 = a semi-infinite substrate (absorbing)
I assume:
1. Oblique incidence
2. I already know the amplitude transmittance [tex](t)[/tex]
3. The coordinate system has the origin at the last interface, where +z points down.
Beyond the last interface, the transmittance is
[tex]T = \left| \frac{\hat{n}_{m+1} \cos \hat{\theta} _{m+1}}{n_0 \cos \hat{\theta} _0} \right| \left| t \right| ^2 \exp \left[ - \left( \frac{4\pi \, \kappa_{m+1}}{\lambda} \right) \frac{z}{\cos \theta _{m+1}} \right] \qquad \qquad \mbox{(TE)} \right|[/tex]
[tex]T = \left| \frac{ (\cos \hat{\theta} _{m+1})/\hat{n}_{m+1}}{(\cos \hat{\theta} _0)/n_0} \right| \left| t \right| ^2 \exp \left[ - \left( \frac{4\pi \, \kappa_{m+1}}{\lambda} \right) \frac{z}{\cos \theta _{m+1}} \right] \qquad \qquad \mbox{(TM)} \right|[/tex]
where [tex](\kappa)[/tex] is the imaginary part of the complex refractive index.
This means I can generalize the two transmittance expressions (from the first post) for the case of complex media [3]. I also introduce a decay, because the semi-infinite substrate is absorbing---according to the Lambert law of absorption (in its oblique version) [3]. So, the better way to put it is that the transmittance approaches 0 very fast.
[3] C. Mack, Fundamental Principles of Optical Lithography: The Science of Microfabrication. West Sussex, England: John Wiley & Sons, 2007.
One last thought:
I've found yet another reference [4] with a slightly different expression for the case of a multilayer stack:
[tex]T = \Re \left\{ \frac{\hat{n}_{s} \cos \hat{\theta} _s}{n_a \cos \hat{\theta} _a} \right\} \left| t \right| ^2[/tex]
where "s" and "a" stand for substrate and ambient media, respectively. Of course, this author tells the reader to carry out separate computations for TE and TM-polarized light, but that's really the only formula presented. It appears that the only difference between the two cases is the amplitude transmittance, which does not sound right for a TM calculation. I would expect something like:[tex]T = \Re \left\{ \frac{\cos \hat{\theta} _s / \hat{n}_{s}}{\cos \hat{\theta} _a / n_a} \right\} \left| t \right| ^2[/tex]
Also, notice that he does not take the absolute value of the ratio; he uses the real part of the result instead. What confuses me even more is that he cites [2] as his reference, which does not present the same formalism.
This takes me back to my original question:
How do I compute the transmittance in (absorbing) stratified media? Any help is highly appreciated!
[4] D. L. Windt, IMD - Software for modeling the optical properties of multilayer films, Computers in Physics, 12, 360 (1998).
11K
