Electric Field Due to a Charged Disk
The discussion focuses on calculating the electric field produced by a uniformly charged disk and a ring with the same outer radius. The key point is to compute the electric field at a point P located at a distance of 2.60R from the disk's center. The method involves integrating the contributions of infinitesimal charge elements on the disk and utilizing symmetry to simplify the calculations. The integral for the electric field is given as E = (1/4πε₀) ∫(dq/r²), where dq is defined as ρ da, with ρ being the surface charge density.
  • Understanding of electric field concepts and equations
  • Knowledge of integration techniques in calculus
  • Familiarity with symmetry in physics problems
  • Basic understanding of charge density and its implications
  • Learn how to derive the electric field for a uniformly charged disk using integration
  • Study the electric field produced by a charged ring and compare it to that of a disk
  • Explore the concept of charge density and its effect on electric fields
  • Practice solving problems involving electric fields and integration in electrostatics
This discussion is beneficial for physics students, particularly those studying electromagnetism, as well as educators and anyone interested in understanding the principles of electric fields generated by charged objects.
jrz5036
Suppose you design an apparatus in which a uniformly charged disk of radius R is to produce an electric field. The field magnitude is most important along the central perpendicular axis of the disk, at a point P at distance 2.60R from the disk. Cost analysis suggests that you switch to a ring of the same outer radius R but with inner radius R/2.00. Assume that the ring will have the same surface charge density as the original disk. If you switch to the ring, by what percentage will you decrease the electric field magnitude at P?
E field equations for disk and ring
please tell me how to do it and the answer is ...Thanks```
Well, you're going to have to do some integrating. Also, you'll need to make use of symmetry. I'll get you started. It would be a good exercise to separately compute the electric field for a solid disk and then the ring. Draw yourself a picture of a disk of radius R and mark the point P where you want the electric field. You're going to have to sum up the contribution of little charge elements on this disk to the total electric field at point P. Label a little piece of charge on the disk and sketch in the electric field it makes at P.
You can define your bit of charge as
[tex]dq = \rho da[/tex] where rho is the charge density per unit area. Now, for each piece of charge on the disk there is another piece diametrically opposite to it. That means that at P there will be a cancellation of components of the electric field vectors such that the resultant electric field is along the axis perpendicular to the disk. That's great because it simplifies your analysis.
By now you should have figured out that you'll need to integrate over the disk to add up the charge . I'll give you the integral:
[tex]E = \frac{1}{4 \pi \epsilon_o} \int \frac{dq}{r^2}[/tex]
I gave you dq above, so you'll have to figure out da. You will also have to figure out how to express [tex]r^2[/tex] in terms of the geometry. Important note: r in the equation above is the distance from the piece of charge to point P. You will have to represent the radius of the disk as you integrate with some other letter or you will mess up! Your limits of integration will depend on whether you choose to express da in terms of one variable , or two. Hint: if you choose two integrals, one of them will have limits from 0 to 2 pi.
I think this will get you started. Once you understand how to calculate the electric field for the whole disk, the ring will be a piece of cake.
  • · Replies 23 ·
