Help designing a thermistor circuit
The discussion revolves around designing a thermistor circuit for temperature measurement using a microcontroller with an 8-bit ADC. Participants explore the use of a potential divider and linear approximation for temperature readings, while addressing challenges in calculating resistance values and ensuring accuracy over a specified temperature range.
  • Some participants suggest using a potential divider for the thermistor circuit and inquire about calculating the necessary resistance values.
  • Others propose that a linear approximation may not be accurate and recommend creating a calibration look-up table based on empirical measurements.
  • A participant mentions the importance of considering the thermistor's tolerance and the effect of manufacturing variations on the design.
  • One participant shares their experience with sampling NTC thermistor characteristics at multiple points to improve accuracy through linear interpolation.
  • Another participant raises concerns about the linearity of thermistors and suggests using a simple network to linearize the response.
  • Some participants discuss the potential need for operational amplifiers to manage voltage levels and offsets in the circuit.
  • There are inquiries about the specific thermistor part number and the lack of available datasheets for the provided resistance values.
Participants express differing views on the effectiveness of linear approximation for thermistor readings, with some advocating for empirical calibration methods while others highlight the limitations of using only two data points. The discussion remains unresolved regarding the best approach to achieve accurate temperature measurements.
Limitations include the reliance on only two resistance values to define the thermistor's behavior, which may not accurately represent its characteristics across a broader temperature range. Additionally, the discussion touches on the potential non-linearity of thermistors and the need for calibration.
rusty009
I want to design a thermistor circuit to be sampled by a microcontroller using an 8 bit ADC, with a voltage reference of 2.55V, I know the following
T (ºC) R(ohms)
25 2815
40 1200
I am going to use a potential divider then use a linear approximation to measure the temperature. I have two problems, firstly I don't know how to calculate the resistance needed for the potential divider, and secondly how do I calculate from the linear approximation, should I make a line between the two points given ? Thanks in advance !
T (ºC) R(ohms)
25 2815
40 1200
I'm impressed by this entry at wikipedia.org:
http://en.wikipedia.org/wiki/Thermistor
Looks like a linear approximation won't be very accurate for you. Probably best to make a calibration look-up table, based on those equations, and on some measurements by you. Do they have a calibration curve in the datasheet for your thremistor?
Hey, I looked at that entry in wikipedia but the linear approximation did not seem to work for me, I have done,
gradient k=(2815-1200)/(25-40)=107.67
but k*25 does not equal 2815, am I making a stupid mistake here? I need to use a linear approximation, how would I go about calculating the resistance value for the potential divider ?
Well, first you would plot the resistance versus temperature graph -- are you only intersted in temps between 25C and 40C? What is the temperature range you want to cover? Also, what is the *tolerance* of the thermistor over the temperature range you want? If it is +/-10% from unit to unit, you will need to include that in your design (so the reading does not top out or bottom out due to manufacturing variations in the thermistors).
The job of your circuit will be to translate something about the thermistor resistance in that target resistance range, into the voltages 0-2.55V. You will most likely use an opamp to do this, probably running between +/-5V or +/-12V with appropriate output clamping. You could also maybe use a more expensive single-supply CMOS opamp, running just between 0V and 5V.
Is the thermistor resistance dependent on the current you pass through it, or is it just dependent on temperature. If there is a "best" current, make that current with an opamp, and buffer the voltage across the thermistor with another opamp. Then process that buffered voltage with an offset subtractor and a scaling stage, to get you to what you want into your ADC.
If there is a wide tolerance on the thermistors, you can consider doing a calibration step as part of bringing up the circuit, either in the analog circuitry ouside, or in the uC after the ADC.
Show us what you come up with.
Hey, thanks for the reply. I am only interested in temperatures between 25 and 40 degrees. Is there a way to do it without an op-amp as I only have a microcontroller with an 8 bit ADC. I have just plotted the linear approximation in matlab, I have uploaded the file.
edit: the thermistor is only dependent of the temperature.
What do you mean you only have an ADC? Does it already include the sample-and-hold circuit that feeds into most ADCs? Or is it on the uC itself?
To do the offset, you will need to have a negative supply available. Do you have that?
If you don't need full 8-bit resolution, you can just bias it with a resistor that gives you 2.55V when the thermistor is max resistance, and do the offset in your uC.
I have to bail for tonight. Hopefully somebody else can pick this up with you if you still have questions.
The ADC includes a sample-and-hold circuit and I do have a negative supply available.
I don't understand what you mean by this...
Do you have the part number of the thermistor?
no, all the info I was given is listed above.
For a my old design I've to retrieve the temperature from a NTC thermistor using a PIC microcontroller.
I've solved it by sampling the NTC characteristics in several point (10 interval from 0 to 150 °C) and after that I've calculated the linear approximation coefficient for every interval.
To obtain the measured temperature then I've just to measure the thermistor voltage and then find the right sub-interval, after that by using the linear interpolation formula (with the right coefficient) I'm was able to retrieve the estimated temperature. Overall error was less than 1%.
Hope it help
Regards
Grinch
Grinch,
thanks a lot, your response has helped me. I have the linear coefficient for my desired interval, but how did you calculate the resistance to be connected to the thermistor ? Also, how did you calculate the error in the estimation? Thanks.
rusty009
I couldn't find any data sheet even close to the values you posted and only 2 points cannot define a curve so this solution is purely a guess. As Berkeman said, thermistors are not very linear and your linear approximation will not be very accurate. I did quick attempt at a simple network to linearize it a little.
To the +5V supply connect the thermistor and a 5.1 k resistor in parallel. To the other side of the thermistor and 5.1 k resistor connect a 430 ohm resistor to ground. Connect the input of the A/D converter to the junction between the two resistors and the thermistor. Program the microcomputer to divide the A/D output (0 to 255) by 3.825 to get temperature.
Thermistors follow an exponential curve fairly closely. You can use the 40ºC (T=313K) data to find To in this equation:
[tex] \ \ \ R =2815\Omega \cdot e^{T_o \cdot (\frac{1}{T}-\frac{1}{298K})}<br /> [/itex]<br /> <br /> (T is absolute temperature here)<br /> <br /> Or, equivalently, you could do a linear interpolation of ln(R) vs. 1/T<sub>absolute</sub>[/tex]
I had a similar design task a couple years ago: 8 bit AtoD, thermistor input measuring water temperature. There was insufficient resolution over the required temperature range at one end.
I'm getting a little flustered, becaue I though I recalled using a bridge with a thermistor in one leg... In anycase, I was able to restore sufficient linearity, that the accuracy out of the ADC was obtained.
A simple voltage divider may be enough to restore required linearity and resolution as both this
[tex]V = V_{bias} \frac{R_{therm}}{R + R_{therm}}[/tex]
and this
[tex]V = V_{bias} \frac{R}{R + R_{therm}}[/tex]
are themselves nonlinear in [itex]R_{therm}[/itex] .
skeptic2 said:
rusty009
Thanks A LOT for this, but where does the number 3.825 come from ?
rusty, you never did say how much temperature error is allowed in your output.
I have been asked to calculate the error after I have built it. How would I go about calculating this ?
I took the formula for resistance vs. temperature for thermistors, adjusted it to fit your points and calculated the resistor values to give a fairly well centered curve. Since the A/D presumably reads 2.55 V as 255, I multiplied the voltage by 100 at each temperature and divided by that temperature. Then I took the average of the quotients or 3.825 in an attempt to minimize error. This was not a rigorous solution and there are likely better ones.
You require the tolerance of the thermistor to do this, for one. But you say you don't have a part number.
Is this a one-off -- only one made? In this case you can arrive at error emperically by comparing it to another thermometer in the same bath.
Ok, please look at the image below to see what I have made, please tell me if its completely wrong, the maximum resistance I can get is at 25 degrees which is 2815 ohms. I have an input of 5 V so a resistor of 2740 Ohms will take away 2.45 volts leaving 2.55 for the maximum input of the ADC.
just realize that if you're using the +5VDC power supply, this will never be accurate, and you'll have to factor power supply variation and noise into your error calculation.
if you want something accurate, you'll need to use a voltage reference.
I think that's the circuit you need, if you swap the thermistor and resistor and take the reading off the resistor.(?) I thought you were going to follow sceptic's schematic, so I didn't have to work it out.
But your values are a little too idealized. Your part may be good to 5% at 25C. If your part is 5% high or low, you are going to overflow your ADC.
Do you know some calculus? It would help, in this case. sceptic's idea of a reistor in parallel with the thermistor might go for improving linearity--but it takes some calculus to find out--or a spreadsheet, or whatever mathpackage you might have.
How many of these devices are going to be made? It makes a big difference in the advice you get.
rusty009 said:
Grinch,
Dear Rusty,
all you've to do is make a subinterval division of your operating temperature range, in my case 10 iunterval was fine to reach a maximum error less than 1 %.
My setup was a simply 5 V reference with a 1% resistor in series with the thermistor then the intermediate point between the first resistor and the thermistor was connected directly to the PIC ADC channel input.
When the temperature change also the thermistor resistance will change and with the readed voltage you are able to retrieve the estimated temperature. Let me some time to retrieve the original file and I'll give you full example.
Bye
Grinch
Thanks for all your replies, first of all this what I have been asked to do,
The temperature region of interest is between 25ºC and 40ºC, with resistance of 2815 and 1200 ohms respectively.
The thermistor will be sampled by a microcontroller using an 8 bit ADC, with a voltage reference of 2.55V (Maximum voltage input).
Using a potential divider, calculate the resistance required to drive the thermistor which will have one terminal grounded. Draft an algorithm or C source fragment which will convert the ADC value in an 8 bit register into the measured temperature using a linear approximation.
so proton soup your right about the voltage reference but I am not sure how to make this. Also you say that it will never be accurate, how do you know this ?
Actually, Proton, the DACs on these micros are purposely designed for simplified referencing. Using Vcc as both the internal ADC reference and your input reference means that it cancels-out in many input architectures such as rusty's. You just have to pay attention to Vcc noise.
So this is a toy design, that will never be made, and no body cares if it really works well or not, right?
Your thermistor resistance is
[tex]R_T = R_o e^{B(1/T - 1/T_o)}[/tex]
[tex]R_T[/tex] is the thermistor resistance
[tex]R_o = 2815 \ \ \ \ B = 6211 \ \ \ \ T_o = 323[/tex]
T is in units of degrees Kelvin.
The input temperature range is 323.15 to 338.15 Kelvin.
Thermistors might have [tex]R_T[/tex] good to 4% from the idealized curve.
The curve is concave up, with 12% error from linear at the midpoint resistance. (This is conservative for an exponential curve to staight line comparison.)
[tex]V = V_o \frac{R}{R+R_T} \ \ \ \ V_o = 5[/tex] volts.
[tex]V[/tex] is also the ADC count. [tex]R[/tex] should be chosen to be 30.1K 1% so the upper counts don't overflow the ADC due to input tolerances.
This curve is concave down, with 8% error in V at it's midpoint. Good to fair. This helps cancel the 12% thermistor nonlinearity.
You're only utilizing ADC counts 142 to 242. Assume 1% count error.
Overall percent error is about [tex]\sqrt{1^2 + 4^2 + 4^2 + 1^2} = 5.8[/tex] % That's 5.8% of 15 degrees of span.
Overall that's about 0.9 C error. Bleh.
To get any better, the bias resistor, R should be about 20K, but that means referencing the thermistor not to ground but 1.2V, or so, below.
Could you have meant
V = Vo * Rt/(R + Rt), Vo = 5 V
R = 3.01 K and
B =5302?
well if that's the case, a voltage ref would make it worse
  • · Replies 22 ·
  • · Replies 32 ·
  • · Replies 22 ·
