How Does Acceleration Affect Tension in a Cable Car System?
The discussion focuses on calculating the difference in tension between adjacent sections of a pull cable in a cable car system, specifically when the cars are at their maximum permissible mass of 2800 kg and accelerating at 0.81 m/s². The tension for car 3 is calculated as 97,948.36 N, while for car 6, it is 241,468.9 N. The resulting difference in tension between these two cars is 143,520.54 N. The calculations utilize the equations of motion and trigonometric functions to account for the incline of 35 degrees.
  • Understanding of Newton's second law (Fnet = ma)
  • Knowledge of trigonometric functions, specifically sine
  • Familiarity with free body diagrams in physics
  • Basic principles of tension in cable systems
  • Study the effects of varying angles on tension in cable systems
  • Learn about the dynamics of multi-car cable systems
  • Explore advanced applications of Newton's laws in engineering contexts
  • Investigate the role of friction and air resistance in cable car systems
Physics students, mechanical engineers, and anyone involved in the design or analysis of cable car systems will benefit from this discussion.
aebrenn
Figure 5-60 shows a section of a cable car system. The maximum permissible mass of each car with occupants is 2800kg. The cars, riding on a support cable are pulled by a second cable attached to the support tower on each car. Assume that the cables are taut and inclined at an angle theta = 35 degrees. What is the difference in tension between adjacent sections of pull cable if the cars are at the maximum permissible mass and are being accelerated up the incline at .81 m/s squared.
the drawing shows three cars in a "section." there is a cable each of the cars is hanging from on along the top and another cable parallel that is the "pull" cable running alone the towers of the cars.
Fnet = ma
I calculated the tension from car 3 and the tension from car 6 (the top car of the second section) and then found the difference between them. Free body diagram for car 3 shows the car with a weight force coming straight down, tension force balancing that up, tension force 35 degrees above the positive x direction and weight force 2mg equal to two cars heading in the direction directly opposite of the tension force (at an angle down). Used trig to find the weight force down at an angle = mg/sin theta
Sums of forces:
Car 3 : sum of fnet = ma
T - 2mg = ma
T - 2(mg/sin theta) = ma
T = ma + 2(mg/sin theta)
T = (2800)(.81) + 2((2800x9.8)/sin 35)
T = 97948.36 N
Car 6 : sum of fnet = ma
T - 5mg = ma
T - 5(mg/sin theta) = ma
T = ma + 5(mg/sin theta)
T = (2800)(.81) + 5((2800x9.8)/sin 35)
T = 241468.9 N
241468.9 - 97948.36 = 143520.54
change in Tension = 143520.54 N
The diagram is missing and (IMO) the description is insufficient to properly understand the problem.
Also, there is (at least one) inconsistency: the description of the (missing) diagram says it shows ‘three cars’; but later in the post there is a reference to ‘car 6’.
  • · Replies 18 ·
  • · Replies 42 ·
