Building a Generator to Power Home: Questions and Answers
  • Thread starter Thread starter livingbios
    Generator
This discussion focuses on building a generator to power a home using a DC alternator and a power inverter. The user seeks to achieve an output of approximately 5kW, exploring the possibility of running multiple inverters in parallel. It is confirmed that synchronizing inverters is crucial to prevent damage. Additionally, the complexity of designing a 5kW inverter is highlighted, advising against it for beginners.
  • Understanding of DC alternators and their operation
  • Knowledge of power inverters and their functionality
  • Familiarity with electrical schematics and circuit design
  • Basic concepts of electrical wiring and gauge specifications
  • Research how to synchronize multiple inverters for parallel operation
  • Learn about designing and building a 5kW inverter
  • Study wire gauge specifications and their current handling capabilities
  • Explore safety precautions and best practices in DIY electrical projects
Hobbyists interested in DIY electrical projects, electrical engineering students, and anyone looking to build a home generator system.
livingbios
hey all :)
i'm completely new to the electrical game, but I'm very interested in this, however only as a hobby. I'm doing my best to learn as much about this as possible so please excuse my stupid questions.
ok so I'm interested in building a generator to power my home in case of outages. i could buy one, but it'd be much more fun to build one, right? :biggrin: ok i already have everything designed, but i will be using a dc alternator so I'm going to need to convert this to ac obviously. so I'm going to use a power inverter to accomplish this (unless there is another way?). since it's going to be hand built i would like to try to build one of these as well. I've already found a schematic for this, but the max output from this particular design is 1kw. I'm looking for an output of ~5kw, the more the merrier though. my question is, could i run these inverters in parallel to achieve this? maybe somebody can provide me with a schematic to build a larger inverter if not. like i said, i have no idea about any of this really, but i would like to do this. another question i have is that if i was to just buy a large inverter, i would obviously have to run a larger wire for the input, but how much larger?
any insight, advice and direction is much appreciated.
Running inverters in parallel is possible if you synchronise them. If you are off by a few degrees in phase, then you can blow them up.
Building a 5kw inverter is a different ball game. You have blow the schematic of a 1 kw inverter out of proportions. If are you new to electronics I wouldn't attempt building such an inverter as a first project. Here is a list of different wire gauges, and how many amps they handle
http://www.powerstream.com/Wire_Size.htm
  • · Replies 38 ·
  • · Replies 47 ·
10K
