Why would smaller seeds be more sensitive to saline water than larger seeds?
  • Thread starter Thread starter rowkem
    Water
The discussion revolves around the sensitivity of smaller seeds to saline water compared to larger seeds, based on an experiment that measured radicle lengths under varying salt concentrations. Participants explore the reasons behind the observed differences in sensitivity and the experimental design used to assess these effects.
  • Experimental/applied
  • One participant notes that smaller seeds exhibited shorter radicles when exposed to saline solutions, suggesting greater sensitivity to salt.
  • Another participant draws an analogy between saline concentrations in different volumes of water to explain the potential impact of seed size on sensitivity.
  • Questions arise regarding the experimental design, particularly whether the radicle lengths were compared to control groups of seeds not exposed to NaCl.
  • Concerns are raised about the validity of the experiment's conclusions, emphasizing the need for control comparisons to account for inherent size differences in radicle lengths between small and large seeds.
Participants express differing views on the experimental design's adequacy and its implications for interpreting the results. There is no consensus on the conclusions drawn from the experiment, and questions remain about the methodology.
Limitations include potential missing control comparisons for both small and large seeds, which could affect the interpretation of the results regarding sensitivity to saline water.
rowkem
So, we did an experiment where we exposed two different sizes of seeds to varying concentrations of salt water. The "small" seeds had, on average, shorter radicles than the larger seeds. So, it seems that smaller seeds are more sensitive to the saline solution.
I'm just a little confused as to why. All the lit. I've looked at doesn't seem to explain why such a thing occurs. I've assumed that there is more NaCl per mass unit for the smaller seeds but, that's as far as I've got it. Please help and cite sources used, if any. Thanks,
Think about it for a bit.
If you put a drop of saline solution in a cup of water and in a gallon of water, which one has the higher concentration of saline? Even if it's a drop, the cup of water has the higher concentration in comparison to the gallon.
Same thing with the seeds
rowkem said:
So, we did an experiment where we exposed two different sizes of seeds to varying concentrations of salt water. The "small" seeds had, on average, shorter radicles than the larger seeds. So, it seems that smaller seeds are more sensitive to the saline solution. I'm just a little confused as to why.
Your confused? I'm confused by your description.:confused:
Were you exposing small versus large seeds (not seedlings) to differing concentrations of NaCl? You mention the small seeds on average, had shorter radicles. Was that compared to a control group of small seeds unexposed to NaCl? Same question goes for the larger seeds, were you comparing them to a control group?
So, we were using ungerminated seeds for the experiment. The comparison to radicle length was made between the two types of seeds. The smaller seeds had longer radicles compared to the larger seeds; given equal exposure to an NaCl concentration.
If that's the way experiment was done it doesn't prove anything. It seems rather obvious that smaller seeds will have smaller radicles and larger seeds will have larger ones, regardless of water used. That's why Ou asks about the control group - you should put identical small/large seeds in normal water to be able to compare their radicles with these of seeds put in salty water.
  • · Replies 75 ·
9K
19K
