Magnetostatics - Determine the magnetic field
The discussion revolves around determining the magnetic field at a specific point due to two perpendicular current-carrying wires. The subject area is magnetostatics, focusing on the interaction of magnetic fields generated by electric currents.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants express uncertainty about the appropriate equations to use for calculating the magnetic field from multiple wires. Questions arise regarding whether to treat each wire separately or to use a combined approach for the two currents.
Some participants have provided guidance on treating each wire independently to find the magnetic field at the specified point, suggesting that the fields should be combined vectorially. There is an acknowledgment of the need for clarification on the methodology, but no consensus has been reached on the specific calculations.
Participants mention feeling overwhelmed by the pace of the coursework, indicating that they are still grasping foundational concepts related to magnetostatics. There is a request for additional resources to aid understanding.
confusedgirl
Two wires carrying currents of 4A and 6A, respectively, are oriented perpendicular to each other and cross without electrical connection at the origin. Determine the magnetic field magnitude and direction at the point (2, 4).
[bI don't even know what equation to use for this. All we have learned is that F=qV x B. That doesn't seem to have much bearing on the problem at hand.[/b]
Don't know where to start...if anyone has a link to something that explains these types of problems that would be highly appreciated. The teacher has been teaching us a chapter of AP Physics a day and I am getting a bit left behind. Thanks.
I'm not understanding how to calculate two wires instead of just one. Should I use the equation that involves two currents or calculate both of the wires and somehow combine them?
Treat each wire separately. Find the magnetic field at the point in question from each wire, then add them up to find the total field. (Direction counts--the field is a vector quantity.)
Alright, thanks...that clarifies a lot.
