Solving Marble in Container Problem: Find Forces at A, B & C & Between Marbles
  • Thread starter Thread starter 539ay868h
    Container Marble
The problem involves analyzing the forces acting on two uniform marbles stacked in a container, focusing on the points of contact between the marbles and the container. The subject area pertains to statics and force analysis.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss identifying the forces acting on the marbles and consider the implications of symmetry in the setup. One participant attempts to calculate angles related to the geometry of the marbles and the container.
The discussion is ongoing, with participants exploring different approaches to the problem. Some guidance has been offered regarding the identification of forces and the use of symmetry, while others are actively questioning the validity of their methods and calculations.
Participants are working within the constraints of the problem as posed, including specific measurements and the requirement to find forces at designated points without additional context or figures provided.
539ay868h
Hi all. I am stuck at this question for quite some time. Not really sure on how to go about solving it. Please help! Thanks in advance.
Two uniform 77.4-g marbles 2.23 cm in diameter are stacked as shown in the figure in a container that is 2.70 cm wide.
a) Find the force that the container exerts on the marble at the point of contact A.
b) Find the force that the container exerts on the marble at the point of contact B.
c) Find the force that the container exerts on the marble at the point of contact C.
d) What force does each marble exert on the other?
It's a statics problem, so what does that tell you? Start, as usual, by identifying all the forces acting on each marble. Hint: Use symmetry to figure out the point where the marbles touch.
I took the width of the container to minus the 2 radius of the marbles to get the horizontal length of the right-angle triangle (the blue line in the image).
2.7-2.23=0.47cm
then i took used cos(theta)=0.47/2.23
theta = 77.8
is this the correct approach?
great problem
2.7-2.23=0.47cm
theta = 77.8
Excellent! Keep going.
12K
  • · Replies 42 ·
