Finding Axial and Shear Loads in Stiffened Shear Panels: Step-by-Step Guide"
  • Thread starter Thread starter quyn123
    Shear
The discussion focuses on calculating axial and shear loads in stiffened shear panels. The shear loads were determined to be 70.7 kN on the two most horizontal edges and 30 kN on the vertical edge. The axial force in the vertical stiffening rod is expressed as 30 - 0.5*y (where y is in mm), while the axial forces in the upper and lower horizontal stiffening rods are 0.505076*x and -0.505076*x, respectively. The shear flow across all four edges of the panel web is established at 0.50 kN/mm.
  • Understanding of shear panel mechanics
  • Knowledge of axial load calculations
  • Familiarity with structural analysis concepts
  • Proficiency in using kN and mm as units of measurement
  • Study the principles of shear flow in structural panels
  • Learn about axial load distribution in stiffened panels
  • Explore advanced structural analysis techniques using software tools
  • Investigate the effects of varying load conditions on shear and axial forces
Structural engineers, civil engineering students, and professionals involved in the design and analysis of shear panels will benefit from this discussion.
quyn123
Hey guys.
The question states:for the following beam, find the axial loads in the stiffening rods and the shear loads acting on each of the following edges.
I basically worked out the shear for the panels by making an imaginary cut and letting internal momment equal to zero. Giving 70.7KN on the two most horizontal and 30KN on the vertical . The part that I am stuck is is how do I calculate the the axial loads in the stiffening rods?
Cheers for the help.
quyn123: I would say the axial force (in kN) in the vertical stiffening rod is 30 - 0.5*y, where y is in units of mm. The axial force (in kN) in the upper, almost horizontal stiffening rod is 0.505 076*x. The axial force in the lower, almost horizontal stiffening rod is -0.505 076*x. I would say the shear flow on all four edges of the panel web is q = 0.50 kN/mm.
14K
  • · Replies 42 ·
11K
10K
