Describing all unique 2-tuples from a set using Set Notation
The discussion revolves around describing unique 2-tuples generated from a set using set notation, focusing on conditions that prevent symmetry and duplicate elements within the tuples. Participants explore the implications of ordering elements in a set and the conventions of proper set builder notation.
  • One participant proposes a set notation for unique 2-tuples from a set, emphasizing conditions that prevent equal components and symmetry.
  • Another participant challenges the initial notation, noting that it allows for both (x1, x2) and (x2, x1) as distinct tuples, which contradicts the symmetry condition.
  • A suggestion is made to introduce a linear order on the set to satisfy the conditions for generating unique tuples.
  • Questions arise regarding the applicability of ordering elements in a set that lacks numerical values, with a focus on whether distinctness or countability allows for such ordering.
  • Clarifications are sought on the conventions of set builder notation and what needs to be explicitly stated when defining sets and their relationships.
  • A later reply suggests generalizing the definition of the set by treating it as an ordered set, which simplifies the notation and aligns with the conditions discussed.
Participants express differing views on the necessity of ordering elements and the implications of set notation. There is no consensus on the best approach to describe the set while adhering to the specified conditions.
Participants discuss the implications of finite sets and bijections to natural numbers as a means to establish order, but the specifics of these mappings and their necessity in notation remain unresolved.
el_llavero
Describing certain 2-tuples from a set using Set Notation
How do you describe, using set notation, a certain set of n-tuples generated from a set satisfying the following conditions
Condition 1: non of the components of an individual n-tuple can equal each other
Condition 2: if (a,b) is an element of the set then (b,a) can not be an element of the set as well, I believe this is called not being symmetric
I believe the above conditions are analogous to generating all unique n-element subsets from a set, except I need to convert to n-tuple form
For instance, I have a set A = {S1, S2, S3, S4, DS1, DS2}, I would like to describe the set consisting of all the following 2-tuples generated from A, using set notation.
That is, describe the set below using set notation
S = {(S1,S2), (S1, S3), (S1, S4),(S1, DS1), (S1, DS2), (S2, S3), (S2, S4),
(S2, DS1), (S2, DS2), (S3, S4), (S3, DS1), (S3, DS2), (S4,DS1), (S4, DS2), (DS1, DS2)}
This is my best attempt
S= {(x1 , x2): {x1 , x2} [tex]\subseteq[/tex] A}
I'm assuming that by stating ({x1 , x2} [tex]\subseteq[/tex] A) that alone guarantees generation of all unique subsets which satisfy the conditions above, where the x1 , x2 of each generated subset are assigned to the x1 , x2 values of the 2-tuple
Actually, you now have both (x1, x2) and (x2, x1) which are distinct 2-tuples, because {x1, x2} and {x2, x1} are both subsets of A.
And depending whether you want to consider {x, x} as a stupid way of writing {x}, your other condition may not be satisfied either.
The best I can think of at the moment is to introduce a linear order < on A, and write something like
[tex]S_n(A) = \{ (x_1, x_2, \cdots, x_n) \mid x_i \in A \text{ and } x_1 < x_2 < \cdots < x_n \}[/tex]
(I generalized your notation, what was S is now S2(A)).
I see how that works. However, could you enlighten me on the applicability of ordering, that is, when you can introduce ordering on a set where the elements have no numberical value.
for instance
A = {square, pizza, egg, dog}, and |A|= 4
It's obvious square != pizza but does the applicability of ordering come from the fact that
A is a countable set and/or that the elements in A are distinct and/or some other reason?
A finite set can obviously be ordered.
The natural numbers can also be ordered: 1 < 2 < 3 < ... A set is countable if there is a one-to-one mapping into the natural numbers. You can use this mapping to make an order on any countable set.
Thank you for your insight, I am familiar with the concepts of a set being finite and therefore being countable since there is a one-to-one mapping into the natural numbers which I've used in a proof once, I believe it's termed dove tailing, so my only exposure to this is when I have explicitly had to show it.
Now I just need clarification on the conventions of proper set builder notation to describe these relationships and this set.
My question now is:
WHAT IS IMPLIED AND WHAT DO I HAVE TO ACTUALLY STATE?
For instance in my original problem would describing set A and Set B as done below satisfy all conditions? Or do i explicity have to show the mapping from the elements in A into the natural numbers? Does describing A as a finite set as done below encompass all information to later use it in S and order it a certain way.
[tex]S_n(A) = \{ (x_1, x_2) \mid x_i \in A \text{ and } x_1 < x_2 \}[/tex]
I would say that making the statement more general by replacing
Let A be {S1, S2, S3, S4, DS1, DS2}​
in your definition by
Let (A, <) be an ordered set​
is an elegant way to do it.
Then the statement a < b makes sense and you can define
[tex]S(A) = \{ (x_1, x_2) \mid x_1, x_2 \in A \text{ and } x_1 < x_2 \}[/tex]
without anything else. That this is always possible when A is a finite set is then a corollary: it immediately follows from the fact that there exists a bijection between any finite set with n elements and the numbers {1, 2, ..., n} which can be used to introduce an ordering. The formal proof would be something like:
Let A be a finite set with n elements. Then there is a bijection f between A and {1, 2, ..., n}. Now introduce an order < on A by
a < b iff f(a) < f(b)​
where the "<" symbol on the right denotes the familiar "less than" relation on {1, 2, ..., n}.​
  • · Replies 20 ·
  • · Replies 16 ·
