Regression SS in multiple linear regression
In multiple linear regression, the regression sum of squares (SSR) is indeed equal to ∑ (Y_i hat - Y bar)^2, consistent with the definition in simple linear regression. The discussion clarifies that while the formula remains the same, the matrix notation is essential for understanding complex relationships and deriving normal equations. The matrix approach facilitates hypothesis testing and provides insights into degrees of freedom and residuals, which are not easily visualized in simple linear regression.
  • Understanding of multiple linear regression concepts
  • Familiarity with matrix algebra and notation
  • Knowledge of regression diagnostics and hypothesis testing
  • Proficiency in statistical software for regression analysis
  • Study the derivation of normal equations in multiple linear regression using matrix notation
  • Learn about the properties of projection matrices in regression analysis
  • Explore hypothesis testing techniques in the context of multiple linear regression
  • Investigate the implications of degrees of freedom in regression models
Statisticians, data analysts, and researchers involved in regression analysis, particularly those working with multiple linear regression models and matrix algebra.
kingwinner
In MULTIPLE linear regression, is it still true that the regression sum of squares is equal to
∑ (Y_i hat -Y bar)^2 ?
My textbook defines regression SS in the chapters for simple linear regression as ∑ (Y_i hat -Y bar)^2, and then in the chapters for multiple linear regression, the regression SS is defined in MATRIX form, and it did not say anywhere whether it is still equal to ∑ (Y_i hat -Y bar)^2 or not, so I am confused...
If it is still equal to ∑ (Y_i hat -Y bar)^2 in MULTIPLE linear regression (this is such a simple formula), what is the whole point of expressing the regression SS in terms of matrices in mutliple linear regression? I don't see any point of doing so when the formula ∑ (Y_i hat -Y bar)^2 is already so simple. There is no need to develop additional headaches...
Thanks for explaining!
I think you have notation (and/or terms) confused. In simple linear regression
[tex] \begin{align*}<br /> SSTO & = \sum(Y_i - \bar Y)^2 \\<br /> SSE & = \sum (Y_i - \hat Y_i)^2 \\<br /> SSR & = SSTO - SSE = \sum (\hat Y_i - \bar Y)^2<br /> \end{align*}[/tex]
In multiple linear regression, with matrix notation,
[tex] \begin{align*}<br /> SSTO & = \mathbf{Y}'\mathbf{Y} - n \bar{Y}^2 \quad(=\sum (Y_i - \bar Y)^2)\\<br /> SSE & = \hat{e}' \hat{e} = \mathbf{Y}' \mathbf{Y} - \hat{\mathbf{\beta}}' \mathbf{X}' \mathbf{Y} \quad (=\sum (Y_i - \hat Y_i)^2) \\<br /> SSR & = SSTO - SSE = \hat{\mathbf{\beta}}' \mathbf{X}' \mathbf{Y} - n \bar{Y}^2<br /> \end{align*}[/tex]
The matrix approach isn't here simply to cause confusion: in multiple linear regression the "nice" approach of drawing pictures to represent things breaks down. However, a little linear algebra can be used to describe exactly why the residuals sum to zero, why the different quantities have different degrees of freedom, as well as provide convenient ways to generate tests (there are many theorems that describe the probability distribution of different quadratic forms of multivariate normal distributions: using matrices in multiple regression allow these theorems to be used to develop hypothesis tests.)
On a more basic level: imagine trying to derive the normal equations (to estimate the regression coefficients) by algebra rather than via the matrix approach. It isn't fun.
As one more: example:
The fitted values in multiple regression can be written as
[tex] \hat Y = X \left(X'X\right)^{-1} X' Y \equiv P_V Y[/tex]
where [tex]P_V = X \left(X'X\right)^{-1} X'[/tex] is a projection matrix onto the space spanned by the columns of [tex]X[/tex].
The residuals are
[tex] \hat e & = Y - \hat Y = \left(I - X \left(X'X\right)^{-1} X'\right) Y \equiv P_{\hat V} Y[/tex]
where [tex]P_{\hat V} = I - X \left(X'X\right)^{-1} X'[/tex] is the projection onto the space orthogonal to the column space of [tex]X[/tex].
Now
[tex] \hat e' \hat Y = Y' P_{\hat V} \left(I - P_{\hat V}\right) Y = Y' \left(P_{\hat V} - P_{\hat V}^2\right) Y = Y' \left(P_{\hat V} - P_{\hat V}\right) Y = 0[/tex]
or, in short,
[tex] \sum \hat{e}_i \hat{y}_i = 0[/tex]
just as in linear regression.
Do you know how to prove that
SSE = Syy – Sxy2/Sxx = Syy - β1hat2 * Sxx
  • · Replies 64 ·
  • · Replies 23 ·
