Solution to Puzzle: y = x/ln(2x)
  • Context: Undergrad
  • Thread starter Thread starter qraal
    Puzzle
The discussion revolves around the equation y = x/ln(2x) and the challenge of solving for x, particularly in the context of finding approximate solutions for specific values of y. Participants explore various methods, including numerical techniques and the Lambert W function, to address the transcendental nature of the equation.
  • Some participants note that the equation is transcendental, suggesting that only approximations can be achieved.
  • One participant proposes using the Newton-Raphson method for finding approximate solutions, emphasizing the importance of a good initial guess.
  • Another participant mentions that the function diverges at x=0.5 and has two solutions for certain y-values, indicating the need for careful selection of starting points.
  • There is a suggestion to use the Lambert W function to express the solution, with one participant providing a derivation involving the function.
  • Some participants express uncertainty about the derivation of the Lambert W solution and discuss alternative methods for solving the equation.
  • One participant highlights the advantages of using the Lambert W function in computational tools for quick plotting and analysis.
Participants express differing views on the best methods for solving the equation, with some favoring numerical methods like Newton-Raphson and others advocating for the Lambert W function. There is no consensus on a single approach, and the discussion remains unresolved regarding the most effective solution method.
Participants mention that the function has specific behaviors depending on the value of x, including divergence and the existence of multiple solutions for certain ranges of y. The discussion also touches on the limitations of the methods proposed, particularly in relation to the transcendental nature of the equation.
This discussion may be useful for individuals interested in solving transcendental equations, numerical methods, and the properties of the Lambert W function, particularly in mathematical and engineering contexts.
qraal
Hi All
Is there a solution to the following?
y = x/ln(2x)
...solving for x.
Mathematics news on Phys.org
It is a trancendental equation; the best you can hope for is an arbitrarily accurate approximation to the inverse on some interval.
qraal said:
Hi All
y = x/ln(2x)
...solving for x.
as in x/ln(2x) = 3, find x?
Exactly. If I know y how do I find x?
Though the other poster is making me wonder if an approximate answer can be constructed using a Taylor series or some such.
Hello qraal,
Using the method of Newton-Raphson will give you a fast approximate solution if you have a "good" starting value in the neighbourhood of the solution. The method can be found here:
http://en.wikipedia.org/wiki/Newton's_method
and is for your equation:
[tex]x_{n+1}=x_{n}+\frac{ln(2x_{n})[yln(2x_n)-x_n]}{ln(2x_n)-1}[/tex]
The problem is that the function
[tex]\frac{x}{ln(2x)}[/tex]
is diverging for x=0.5. For values smaller than 0.5 it is negative and for values larger than 0.5 it is positive. However for the positive values it has a minimum and thus two solutions if a y-value is given. So the initial value is best to be determined by plotting it.
As an example use rock.freak667 value of 3. This has two solutions, one in the neighbourhood of x=0.6 and one in the neighboorhood of x=8. These serve as starting values in the iterative scheme and give you very quickly the solutions. I have the following values: x=0.613444 and x=8.499444. I added also a graph of the function to clearify things. If you have any questions please post.
best regards,
coomast
[tex]x=-\operatorname{W}\left(-\frac{e^{-y}}{2}\right)[/tex]
where W is Lambert's W.
This can be solved fairly quickly compared to a general Newton's method based solution.
coomast said:
Hello qraal,
best regards,
coomast
Hi coomast
Thanks for the pointer to Newton's Method. Very useful!
To clarify the problem further, it's an approximate solution to the ratio of proper time versus co-ordinate time for a continuously accelerated starship's crew. Thus x > 1 in all cases I'm interested in.
Hello qraal,
If the x-values are larger than 2 it has a unique solution. In case these can be between 1 an 2 as well you will have two solutions. This is clear from the picture and a substitution in the equation. Indeed, we have for x=1
[tex]y(1)=\frac{1}{ln(2)}[/tex]
whichis the same value for x=2. In between these a minimum exists for
[tex]x=\frac{e}{2}[/tex]
and the y-value is here
[tex]y=\frac{e}{2}[/tex]
So you must have y to be at least e/2 to have a solution. I would suggest to use a large initial value if you know that x>2 or y>1/ln(2) and in case y<1/ln(2) this large value will give one solution, the other can be obtained by setting the initial value to 1.05. Nice equation to study :-)
@CRGreathouse: I can't get to your expression with the function of Lambert. I get by rewritting this expression back to the original form the following:
[tex]x-ln(2x)=y[/tex]
I might be making a silly mistake, it's getting late over here and I'm a bit tired:-) Anyway to find the solution even with Lambert you will need an iterative scheme and Newton-Raphson seems the easiest here. Presumably it will give a similar formula as the one I gave. Or is there another one which is faster?
best regards,
coomast
coomast said:
Hello qraal,
best regards,
coomast
I think there is a mistake in that derivation of the Lambert-W solution. Here's how I would do it.
[tex]\ln(2x) = x/y[/tex]
[tex]2x = e^{x/y}[/tex]
[tex]2x e^{-x/y} = 1[/tex]
Now let [itex]z = -x/y[/itex].
[tex]-2y\,z\,e^{z} = 1[/tex]
[tex]z e^{z} = \frac{-1}{2y}[/tex]
So from the definition of the Lambert W function :
[tex]z = W \left( \frac{-1}{2y} \right)[/tex]
and
[tex]x = -y \, W \left( \frac{-1}{2y} \right)[/tex]
[tex]y=\frac{x}{ln(2x)}[/tex]
[tex]y*ln(2x)=x[/tex]
[tex]ln(2x)^y=lne^x[/tex]
[tex](2x)^y=e^x[/tex]
[tex]x=\frac{e^{\frac{x}{y}}}{2}[/tex]
[tex]2=e^k[/tex]
[tex]x=e^{\frac{x-k*y}{y}}[/tex]
[tex]lnx=\frac{x-k*y}{y}[/tex]
[tex]y*lnx=x-k*y[/tex]
[tex]lnx^y-lne^x=-k*y[/tex]
[tex]ln\frac{x^y}{e^x}=-k*y[/tex]
[tex]ln\frac{x^y}{e^x}=ln(e^{k*y})^{-1}[/tex]
[tex]\frac{x^y}{e^x}=\frac{1}{e^{k*y}}[/tex]
[tex]x^y=z[/tex]
[tex]e^x=e^{k*y}*z[/tex]
[tex]x=z^{1/y}[/tex]
[tex]x=k*y*ln(z)[/tex]
k is constant ≈ 0.693147
z can be any number
This is what I came up with...
and
This is the same result I had. Now the initial remark raised by CRGreathouse was:
"This can be solved fairly quickly compared to a general Newton's method based solution."
What is this other method? Using Newton-Raphson on the Lambert function gives in the end the same interative scheme as the one I proposed. I think the formula obtained is easy and fast enough to get to the solution. If another method is available I would like to learn it, it will be interesting.
best regards,
coomast
What do you think about my solution?
best regards,
coomast
Hi coomast. One obvious advantage of expressing solutions like this in terms of the Lambert W function is that many maths programs (eg Matlab Octave Maple etc) will already have that function implemented, which makes it nice and easy to get a quick plot for example. (see attachment)
Perhaps a bigger advantage however is that if we've already familiarized ourselves with some of the properties of the Lambert-W function then we can immediately deduce many properties of this new function with little effort.
For example, I already know (from past study of W) that W(x) has :
- no real solutions for {x<-1/e}
- one real solution for {x=-1/e} U {x>=0}
- two real solutions for {-1/e < x < 0}
I can then immediately apply this to your new function and work out where it has real solutions (and how many) with very little effort. This is where I think is the real merit lays in expressing the solution in terms of a know function (even if at the end of the day you still have to evaluate it with numerical methods).
BTW. If you apply Newtons method to the W function you can (with a bit of algebra) crunch it down to :
[tex]x_{k+1} = \frac{ x_k^2 + y e^{-x_k}} { 1 + x_k}[/tex]Edit. I temporarily forgot who was original poster in this thread. In the above I was wrongly referring to coomast as the OP. :o
First of all, I certainly agree that your solution is "easy and fast enough". In fact it is *so* fast and *so* easy to implement that I felt the need to add an argument to support even mentioning a different method.
But the W function is sufficiently well-behaved (compared to general functions) that higher-order methods are reasonable. There are good implementations of W (along with good starting points, etc.) using Halley's method floating around the 'net. While any of these higher-order methods could in theory be applied to the problem directly, without caution you'll have convergence issues.
And since it is a general function, you may already have optimized code for W sitting around.
Hi Guys
I can't get it to converge using Newton's Method. It comes close, but converges on an x value that gives a y that's too high by about 3%. *sigh*
What are your numbers?
My target y value is 210713.2394 and my starting x value is 3303361. I used Newton's Method, as per my Maths text and Wikipedia, i.e.
x1 = x0 - f(x0)/f '(x0)
...but it converged somewhere else.
Ah! Discovered my mistake! I set up my initial equation incorrectly. To find x for a specific y* for x/ln(2x) I had to make f(x) = x/ln(2x) - y*, and then use Newton's method. D'Oh! It converged in three iterations to within the limits of accuracy I was using with those numbers.
Coomast, and all, thank you.
[tex]2=e^k[/tex]
[tex]x^y=z[/tex]
z can be any number
Of course not.
Kittel Knight said:
Of course not.
z can be any positive number :-)
  • · Replies 19 ·
  • · Replies 21 ·
