Difficult Differential Equations of Motion
The discussion revolves around a differential equations problem involving a fox chasing a hen, with specific initial conditions and velocities for both animals. Participants explore various approaches to solving the problem, including the formulation of differential equations and the potential use of numerical methods.
  • One participant presents the problem and derives a set of differential equations for the positions of the fox and hen, questioning the solvability of these equations.
  • Another participant suggests denoting the positions simply as x and y and asks about the derivative dy/dx.
  • A participant references similar problems found in differential equations textbooks, indicating that the problem has been studied in various contexts.
  • There is a discussion about the nature of the path taken by the fox, with one participant identifying it as a tractrix or pursuit curve.
  • A later reply clarifies that deriving the curve y=f(x) is more straightforward than deriving x and y as functions of time, which could simplify finding the intersection point with the x-axis.
  • One participant expresses confusion about the role of dy/dx but later acknowledges a better understanding of its significance in the context of the problem.
  • Another participant notes that the coupled ordinary differential equations (ODEs) could be solved simultaneously using various numerical methods.
Participants express differing views on the best approach to solving the problem, with some advocating for numerical methods and others focusing on analytical solutions. The discussion remains unresolved regarding the most effective method to find the solution.
Participants mention the potential complexity of the problem and the existence of similar problems in textbooks, indicating that there may be limitations in the current understanding or approach to the problem.
RFurball
I saw this problem posted on the internet somewhere and am intrigued how to solve it.
The problem is a fox chasing a hen with the following conditions:
1) The fox's starts at position x=0, y=10m (0,10)
2) The hen start's at position (0.0)
3) The fox runs at velocity 4m/s in a direction directly at the hen's current position.
4) The hen runs at a velocity of 3m/s along the x-axis.
The question is how long does it take the fox to catch the hen?
My approach to solve this starts with a position of the fox [tex]F(t)=F_x(t) \vec x+F_y(t) \vec y[/tex]
At this positions the velocity vector is [tex]VF(t)=VF_x(t) \vec x+VF_y(t) \vec y[/tex] where [tex]|VF(t)|=4[/tex]
The position of the Hen is 3t
Based on the position of the 2 animals the ratio [tex]\frac{VF_x(t)}{VF_y(t)}=\frac{3t-F_x(t)}{F_y(t)}[/tex]
Rearranging these equations I come up with the following 2 equations:
[tex]VF_x(t)=\frac{4(3t-F_x(t)}{\sqrt{(3t-F_x(t))^2-F_y(t)^2}}[/tex]
and
[tex]VF_y(t)=\frac{4F_y(t}{\sqrt{(3t-F_x(t))^2-F_y(t)^2}}[/tex]
From physics I know that [tex]v(t)=\frac{ds}{dt}[/tex] which I think I can break into: [tex]V_x(t)=\frac{dF_x(t)}{dt}[/tex] and [tex]V_y(t)=\frac{dF_y(t)}{dt}[/tex]
Plugging these 2 equations I come up with the following 2 equations which are a set of differential equations for Fx(t) and Fy(t):
[tex]\frac{dF_x(t)}{dt}=\frac{4(3t-F_x(t)}{\sqrt{(3t-F_x(t))^2-F_y(t)^2}}[/tex]
and
[tex]\frac{dF_y(t)}{dt}=\frac{4F_y(t}{\sqrt{(3t-F_x(t))^2-F_y(t)^2}}[/tex]
If I could solve for Fy(y) I would find t where Fy(t)=0
Are these equations solveable?
Secondly is my approach to solving correct?
This problem has got to be solveable since it seems simpler than the laws of planetary motion which involve accelaeration and 3 dimesions.
A coulple of observations I calculated are:
If the fox ran along the y-axis then along the x-axis the hen would be caught in 10 seconds so I know the aswer is less than 10seconds.
If the fox ran an angle of atan(3/7^0.5) the hen would be caught in 10/(7^0.5)=3.78seconds so I know the answer is greater than 3.78seconds.
If I run a recursive Excel spreadsheet with small delta t I calculate the answer to be approximately 5.715seconds.
I would use this number as a check of the solution.
Hope the post is legible. I am learning latex on the fly.
Hint: Denote Fx simply as x and Fy as y.
What is dy/dx?
This problem (or equivalent) can be found in many differential equations textbooks:
Flying a plane in a crosswind, always heading straight toward the destination.
Rowing a boat across a river, always heading straight toward the destination.
I first heard it as a farmer chasing a pig.
Here is a solution I wrote up a few years ago
http://www.math.ohio-state.edu/~edgar/H521_02/HW8s4.html
Don't give out solutions, g_edgar.
OK, deleted.
DH
Thanks for your help. I am still a little confused where dy/dx comes into play, I will have to think about it. Maybe I will look in my 20yr old college text on differential equations to see if there is a similar probblem as g_edgar points out. I would guess the path is probably a parabola or hyperbola, maybe I can plug those into the equations.
THe path is called a tractrix, or pursuit curve.
Where dy/dx comes into play is that it is much easier to derive the curve y=f(x) rather than to derive x and y as functions of time. From that, you can easily compute the point at which this curve intersects the x axis. Finally, given the chicken's speed, you can easily compute the time it takes for the fox to catch the chicken.
D_H,
After thinking it over I think I understand now. The derivative dy/dx is the direction the fox is traveling. Therefore the solution would be solving this differential equation [tex]\frac {dy}{dx} = \frac {-y}{3t-x}[/tex] which I havn'e found the solution but that is OK. I just have bugged on how to solve it and I made it way more difficult than need be.
I did look in my college diff eq book and embarassing enough a similar problem is listed on page 12 (out of like 900+ total pages).
For what its worth (not that it will assuage any pure mathematicians on this board), the problem was solved for all practical purposes when you made those two coupled ODE's.
They could be solved simultaneously by a variety of numerical methods.
  • · Replies 19 ·
  • · Replies 22 ·
