Frequency Counter: Counting Closely Amplitudes
A frequency counter connected to an antenna receiving multiple close-amplitude frequencies will struggle to provide an accurate count due to interference and beat patterns. The counter operates by counting zero-crossings, and when two sine waves of similar frequencies are combined, the resulting waveform can lead to unstable displays and inaccurate readings. This occurs because the signals may cancel each other out, resulting in missed counts or a jumble of numbers. It is advisable to avoid connecting multiple signals to a frequency counter to ensure accurate measurements.
  • Understanding of frequency counters and their operation
  • Knowledge of zero-crossing detection
  • Familiarity with sine wave behavior and beat frequencies
  • Basic principles of signal interference
  • Research the principles of zero-crossing detection in frequency counters
  • Study the effects of signal interference on measurement accuracy
  • Learn about beat frequencies and their impact on waveform analysis
  • Explore gating processes in electronic counting systems
Electronics engineers, signal processing specialists, and anyone involved in frequency measurement and analysis will benefit from this discussion.
m718
Which frenquency would a frequency counter count if its connected to an antenna that is receiving several frequencies close to each other in amplitude?
What are your thoughts? Is this for school work?
A frequency counter generally works by counting zero-crossings (or trigger level crossings in a more general case). What do you get if you add two sine waves of similar frequencies? What happens to the zero crossings? (Hint -- sketching it out may help)
What happens is that you get an unstable display. It may give a jumble of numbers or just the MHz part of the number might be OK and the rest is a jumble of different numbers with each count.
The counter sees a waveform that includes a beat pattern between the signals. So, sometimes the counter gets nothing from either signal because they are cancelling each other out. If this happens they won't cause the counter to count at all or to only count some of the pulses that should have been counted.
The counter uses a gating process to count so it all depends on how many usable pulses it gets in each gating period.
Generally, it is bad to have more than one signal coming into a counter.
  • · Replies 49 ·
  • · Replies 68 ·
  • · Replies 28 ·
