How Can You Align a Thin Electrode Parallel to a Surface Without Direct Contact?
  • Context: Graduate
  • Thread starter Thread starter splitringtail
    Components Optics
The discussion focuses on aligning a thin electrode parallel to a surface without direct contact. Key methods include using a non-contact sensor, which can achieve accuracy of less than 1 micrometer, or employing a traveling microscope for measurement. Additionally, utilizing a fixed laser to measure the distance between reflected spots can determine the slope of the electrode. The conversation highlights the need for specialized instrumentation in laboratory settings for precise alignment tasks.
  • Understanding of non-contact measurement techniques
  • Familiarity with laser alignment methods
  • Knowledge of optical principles related to reflection
  • Experience with precision measurement tools like traveling microscopes
  • Research non-contact sensors for precise distance measurement
  • Explore the use of traveling microscopes in laboratory settings
  • Learn about laser alignment techniques and their applications
  • Investigate optical measurement principles and their relevance to electrode alignment
Researchers, laboratory technicians, and engineers involved in precision instrumentation and alignment tasks, particularly in optics and materials science.
splitringtail
I have a apparatus with a thin electrode that is suppose to be parallel with surface beneath it. I can level the surface, but you cannot put a level on this electrode.
I was thinking have like a block precisely made to the expected distance between the electrode and bottom to determine the alignment, but I was thinking if I was not careful I could damage the electrode.
Another thought, maybe use a laser level and calibrated to the level surface, then some how move it up to the elevation of the electrode to check its alignment. However, I have heard that even the levels used by contractors are not very precise and can be quite cumbersome in those applications.
I was wondering if there is any specialized instrumentation and/or produces used in the laboratory setting. I figure those who work in optics have developed something, but I cannot find any information on the issue.
I would prefer to get some direction/recommendation for literature and documentation.
Thank You
Science news on Phys.org
To get it parallel you can either measure the distance electrode-substrate at each end
Using something like this http://www.sensorland.com/HowPage056.html is fairly cheap and accurate to <1um and non-contact. Or you can use an old fashioned traveling microscope to do the same thing.
Another apporach if your electrode is reflective enough is to shine a laser at each end (eg slide the unit under a fixed laser) and measure the distance apart the reflected spots appear on the ceiling. With a bit of trig and assumign the position of the laser is fixed you can work out the slope of the electrode.
  • · Replies 46 ·
9K
