Functional Analysis, Show that the range of a bounded linear operator
The discussion revolves around demonstrating that the range of a bounded linear operator \( T: X \rightarrow Y \) is not necessarily closed, specifically in the context of the operator defined from \( l^{\infty} \) to \( l^{\infty} \).
  • Participants explore the idea of finding an element in \( l^{\infty} \) that does not belong to the range of \( T \) and constructing a convergent sequence in the range that approaches this element. There is also discussion about the behavior of sequences and their limits in relation to the boundedness condition of the operator.
Some participants have offered insights into the nature of the sequences involved and the convergence properties required to address the problem. There is an ongoing exploration of different perspectives on how to approach the construction of limit points and the implications of boundedness.
Participants are navigating the constraints of the problem, particularly regarding the boundedness of elements and the characteristics of the operator's range. There are hints of confusion around the construction of sequences and their limits, indicating that certain assumptions may need to be revisited.
Eduardo
Show that the range [tex]\mathcal{R}(T)[/tex] of a bounded linear operator [tex]T: X \rightarrow Y[/tex] is not necessarily closed.
Hint: Use the linear bounded operator [tex]T: l^{\infty} \rightarrow l^{\infty}[/tex] defined by [tex](\eta_{j}) = T x, \eta_{j} = \xi_{j}/j, x = (\xi_{j})[/tex].
My idea was to find an element [tex]y \in l^{\infty}[/tex] that does not belong to the range and then try to build a convergent sequence in [tex]\mathcal{R}(T)[/tex] that has limit [tex]y[/tex]. The element [tex]y = (1, 1, \ldots)[/tex] satisfy the criteria because [tex]T^{-1}y = \{ x\}[/tex], with [tex]x = (\xi_{j}), \xi_{j} = j[/tex], but, clearly, [tex]x \not\in l^{\infty}[/tex], therefore, [tex]y \not\in \mathcal{R}(T)[/tex]. The problem arise when I try to build the sequence, because [tex](T x_{m})[/tex] with [tex]x_{m} \in l^{\infty}[/tex] cannot converge to [tex]y[/tex]. Briefly, my problem is that I can´t find a limit point of [tex]\mathcal{R}(T)[/tex] that doesn´t belong to [tex]\mathcal{R}(T)[/tex].
Think from the other direction. Since x needs to be bounded, the elements in Tx must decrease to zero eventually. Which means that any element that's on the boundary of the image set must also have its elements converge to zero. Can you find a sequence nk that converges to zero, such that knk is unbounded?
Just, logged into thank you, Office Shredder, for your quick and helpful answer. which was very nice because it was precisely what I needed, to unblock my fixed ideas o a change of approach to face the problem and let me think or find an answer instead of just give me the result inmediately. Thanks again.
who did you find the find a limit point of
R(T)
R(T)?
  • · Replies 43 ·
  • · Replies 0 ·
