Friction in an inclined right-angle trough
  • Thread starter Thread starter Zorodius
    Friction Inclined
The problem involves a crate sliding down an inclined right-angled trough, with a focus on the effects of kinetic friction and the geometry of the trough. Participants are tasked with determining the acceleration of the crate in terms of the coefficient of kinetic friction, the angle of inclination, and gravitational acceleration.
  • Participants discuss the significance of the trough's geometry, particularly the right-angle and potential 45-degree angles, in relation to the forces acting on the crate. Some express confusion about how these factors influence the normal force and frictional force calculations.
There is ongoing exploration of the problem, with participants attempting to clarify the role of the normal forces and how they relate to the gravitational force acting on the crate. Some guidance has been offered regarding the resolution of forces, but no consensus has been reached on the correct approach or final answer.
Participants note the challenge of visualizing the problem in three dimensions and the difficulty in drawing free body diagrams to represent the forces acting on the crate. There is an acknowledgment of the complexity introduced by the trough's shape and the need for careful consideration of the forces involved.
Zorodius
The following problem is from my physics textbook:
A crate slides down an inclined right-angled trough. The coefficient of kinetic friction between the crate and the trough is [itex]\mu_k[/itex]. What is the acceleration of the crate in terms of [itex]\mu_k[/itex], [itex]\theta[/itex], and g?
The problem was accompanied by a drawing which I have tried to reproduce and included as an attachment.
The answer I come up with when I try this is [itex]g(sin \theta - \mu_k cos \theta)[/itex], which differs from the book's answer in that the book's answer has a factor of √2 sitting in front of the cosine.
I think I understand how to do problems involving friction and inclined planes in general, but I do not understand why it matters that the crate is in a right-angle trough, or in a trough at all for that matter. I recognize that a factor of √2 would result from an isosceles right triangle, or from a 45-degree angle, which you could certainly form out of the many right angles present in the problem, but I don't see how any of them would affect the final answer. I have tried to calculate the force the crate exerts on each side of the trough, and then take the vector sum of those two forces to find the net normal force acting upon the crate. When I did this, I found the result to be equal in magnitude to the gravitational force acting orthogonal to the trough - in other words, right back where I started. Perhaps I made a mistake here?
How can I correctly solve this problem?
Okay, you know that the net normal force will simply be perpendicular to the "plane" (imagine the trough was a plane), because the left and right components of the normal forces from the right and left parts of the trought, respectively, will cancel out. If you look a the trough from the side, you can pretty much treat it like a plane (for now), so you have a normal force, and a gravitational force (worry about the friction later). Resolve the gravitational force into perpendicular to the plane and parallel to the plane components. The perpendicular component has magnitude [itex]mg \cos \theta[/itex]; so must the net force. This tells you that each individual normal force (the two of them) have a perpendicular-to-the-plane component of [itex](mg \cos \theta )/2[/itex], and some left or right component. Because of the shape of the trought, being a right angled trough at a 45 degree angle to the ground, you know that the normal forces created by both troughs must be at a 45 degree angle to the ground (because they are at an angle perpendicular to the individual left and right surfaces of the trough). So the normal force from an individual half of the trough is:
[tex]\frac{(mg \cos \theta )/2}{\sin 45 ^{\circ}} = \frac{mg \cos \theta}{\sqrt{2}}[/tex]
The force of friction is of course the sum of the frictions caused by each plank, which is in turn:
[tex]2 \times \mu _k \times \frac{mg \cos \theta}{\sqrt{2}} = \sqrt{2} mg \cos \theta[/tex]
There's your frictional force. The force down the trough due to gravity is obviously [itex]mg \sin \theta[/itex]. Since acceleration is net force divided by mass, you get acceleartion to be:
[tex]g(\sin \theta - \sqrt{2} \mu _k \cos \theta )[/tex]
  • Love
Thanks a lot, AKG!
I do not understand this problem, and since this is my first 3D problem, I can't figure out how to draw a FBD either, so I can't figure out how many forces acting on the crate. It'd be nice if someone could help me out. Thanks
  • · Replies 60 ·
