What is the Convergence of the Product of All Reals?
  • Thread starter Thread starter bubbloy
    Product
The discussion revolves around the convergence of the product of all real numbers except zero. Participants explore various mappings and their implications on the product's value, particularly focusing on whether it can yield consistent results such as -1, 0, or infinity.
  • Participants discuss different mappings, such as a -> 1/a and a -> 1/(2a), questioning their ability to cover all real numbers except zero. There are considerations about pairing terms and the implications of these pairings on the product's convergence.
The conversation is ongoing, with participants raising questions about the definitions and properties of infinite products. Some suggest that the mappings lead to different interpretations of convergence, while others express uncertainty about the implications of pairing terms in the product.
There are concerns regarding the definition of an uncountable product and the convergence of such products. Participants note that the nature of the real numbers complicates the ability to define a consistent product across all reals.
bubbloy
A long time ago I got asked the product of every real number except 0. The person was looking for -1 and the first mapping I tried was a -> 1/a so i got the answer. never really thought about it again. Just realized that you could map a -> 1/(2a) and the answer would seem to be an infinite product of 1/2's. can someone find why this new map wouldn't cover every real number except 0? if it was right, this would imply that the product of every real number is both -1 and 0 and infinity (a -> 2a)
Multiplying every number
pairing a and 1/a
(7*1/7)(8.89765798*1/8.89765798)…*-1 = -1
pairing a and 1/(2a)
(1/2*1)(2/3*3/4)…(7/8*8/14)… = 1/2*1/2*1/2 = (1/2)^∞
i don't find anything wrong with either scheme of pairing the terms
Because this isn't well defined. First of all, how do you define an uncountable product? Second, how do you know this product even converges? It seems to be at best "conditionally convergent" (in the same sense a sum that is conditionally convergent can't be re-arranged at will).
Have you covered infinite series and sequences before? If so the conversation is a lot easier to have
lol yeah I'm a physicist. kind of embarrassed to have this plaguing me. go ahead with whatever level of sophistication you wish to apply
it seems to satisfy the convergence conditions in each case
terms in the product are of the form (a*1/(2a)) = 1/2, each term in the infinite product is then 1/2 which obviously converges.
How about thinking about it like this:
Now, for any positive a, multiplying by -a will just give you an even bigger negative number which we can't do much with. But if we multiplied by -1/a we have automatically made the number -1, and this will happen for all [itex]a\neq 0[/itex].
It also maps through the entire real numbers (not the extended, so don't think of infinite, and also not 0).
Now, the only ambiguity I see here is that there are an infinite number of these values for a, so we can't say if we've multiplied by an even or odd number of (a)(-1/a)
say we take two values of a=2,3
then (2)(-1/2)(3)(-1/3)=(-1)(-1)=1
but for an odd number of products, we get -1.
Sorry, I'm unsure what else to do about this.
Can I just ask how you got the answer from mapping this? I still see the same problem arising as what happened in post #2.
For all a>0, the infinite products of (a)(1/a)=1
For all a<0, the infinite product still fluctuates (I think the correct term is diverges) between 1 and -1 depending on multiplying by an odd or even number of products. So the answer could still be -1 or 1 by this method.
right, i see what you are saying
if you pair each number with it's inverse
you can have every positive number a with 1/a and every negative number b with 1/b, so b and 1/b will cancel their minus signs in every pairing, the only unpairable number will be -1 so that the entire product becomes -1
in your pairing (a with -1/a) the product would seem to fluctuate even in the infinite case
in the a with 1/(2a) pairing the product seems to be 0
if you pair a and 2/a the product seems to be 2*2*2*2*2=∞
is it possible that this can have different products depending on ordering?
I'll reply in this thread since someone else has replied here already (try not to double post threads in the future)
If you want to say what the 'infinite product' is you need to have a reasonable definition. For products of countably many elements this is sort of easy, you just look at finite products with more and more terms and see what it converges to.
With what you want to do it's not so easy. Even if you look at larger and larger products of a finite number of real numbers, you can never order your real numbers in a way so that every single one of them is eventually included in a product (this is because the reals are uncountable). So you need to define your product in some other way than looking at finite products.
It's not surprising that different orderings (even in countable cases) give different values. For example, the infinite series
[tex]\sum \frac{(-1)^n}{n}[/tex] converges and what it converges to changes if you change the order around
But again, in your case you cannot possibly give an ordering of the real numbers so that every real number shows up in one of your finite products, so you are guaranteed to get different values just based on which real numbers you actually decide to look at
This was also posted under "Homework". I am merging the two threads.
When we consider they product of all reals except 0, we can split up the product as such: [a * (1/a)] * [b * (1/b)] * -1 * 1 = -1, where [a * (1/a)] is the product of all a>1 and [b * (1/b)] is the product of all b<-1. This is to be sure that none of the reals are repeated. This is A solution that seems pretty solid to me, so we can be relatively certain that -1 is a solution.
Your (bubbloy) question is if it would work when 1/a or 1/b are replaced with 1/(2a) or 1/(2b) respectively.
It depends on how you look at it. If you treat 1/(2a) as a number by itself, then yes the product converges to 0, and this is due to the nature of the reals.
But, if you look at that product, you're basically saying that the product of all reals is the basically the same as taking the product of all reals multiplied to an infinite number of halves. So they're not really the same ... and I guess that's where the issue of defining the product becomes a problem, because it should work, but it doesn't seem to work.
So, the product of all reals MIGHT approach 0, depending on how you set it up..
I'm not too sure if your mapping (which I'm roughly translating to as a pairing of factors) of a -> 2a works, because it seems like you get repeating numbers in this product i.e. 2*4 and 4*8
Instead of mapping a to 1/(2a), we can also map a to 2/a, and that's how we can get the convergence to infinity. Again, this comes with issues, so it MIGHT be true ...
As Office_Shredder mentioned, once you consider other cases, the problem is whether you accept that all reals are included or not ...
So now it's up to you to choose :)
  • · Replies 21 ·
  • · Replies 32 ·
  • · Replies 21 ·
  • · Replies 24 ·
