Using a magnetic core for an electromagnet
Using a permanent magnet as the core of an electromagnet instead of a standard ferromagnetic core leads to complex interactions due to magnetic hysteresis. Hysteresis is the phenomenon where ferromagnetic materials retain some magnetization after the external magnetic field is removed, resulting in energy loss and memory effects. While it is challenging to cancel the field of a permanent magnet by reversing the current direction, it is possible with a flux integrating coil and an operational amplifier (op-amp) to achieve a net zero flux output.
  • Understanding of magnetic hysteresis in ferromagnetic materials
  • Knowledge of electromagnetism principles and amp-turns
  • Familiarity with operational amplifiers (op-amps)
  • Basic concepts of magnetic field strength and coil configurations
  • Research the effects of magnetic hysteresis on energy loss in electromagnetic systems
  • Learn about the design and application of flux integrating coils
  • Study the principles of operational amplifiers in magnetic field applications
  • Explore advanced electromagnet design techniques for optimizing magnetic field strength
Electrical engineers, physics students, and hobbyists interested in electromagnet design and the effects of magnetic materials on electromagnetic systems.
MaJiK9021
Hi,
I would like to know what would happen if you used a permanent magnet for the core of an electromagnet, instead of the standard ferromagnetic core? Can you increase the magnetic field strength of the permanent magnet by putting current through the coil? Also, could you effectively cancel the permanent magnet's field by reversing the current's direction?
Thanks
Your question is related to Magnetic Hysteresis term in electrical engineering. Hysteresis is associated with the inherent memory of ferromagnetic materials that allows for the creation of permanent magnets. After a magnetic field is applied to a ferromagnet, some of the magnetization is retained, even after the applied field is turned off. So even though you brought the applied field back to its original starting point, the material has not returned to its original state. At the microscopic level, there is a force that tends to oppose the realignment of the microscopic magnets. The dependence of the material’s state on its past history is known as hysteresis.
In addition to memory effects, hysteresis also causes energy loss. When you apply a magnetic field that realigns the microscopic magnets, a frictional effect occurs, and energy is lost to heat. Therefore magnetic hysteresis effects can be useful or non-useful in practice regarding the role of magnetic material which used in construction of electromagnetic systems.
Creative thinking is enjoyable, Then think about your surrounding things and other thought products. http://electrical-riddles.com
MaJiK9021;2410872 Also said:
If you put a permanent magnet in a coil with say H = 400,000 amp-turns per meter, the permanent magnet will be reversed. It is more difficult to cancel the field but it can be done. You will need to put the permanent magnet in a flux integrating coil (attached to an op-amp) and cycle the H amp-turns until the flux integrator output is zero.
Bob S
  • · Replies 26 ·
