Projectile motion with drag and lift
The discussion focuses on solving projectile motion problems involving drag and lift forces for an object tested in a wind tunnel. The initial velocity is 76 m/s, with launch angles of 30, 45, and 60 degrees, and gravity set at 9.81 m/s². The user has tabulated lift and drag forces at wind speeds of 80, 130, and 170 mph, varying the angle of attack from -10 to 30 degrees. The user identified a linear relationship between wind speed and drag values but encountered discrepancies when applying these to the ideal projectile motion equations, indicating a need for further analysis of the lift and drag coefficients (Cl and Cd).
  • Understanding of projectile motion equations
  • Familiarity with lift and drag force calculations
  • Knowledge of aerodynamic coefficients (Cl and Cd)
  • Experience with data interpolation and integration techniques
  • Calculate Cl and Cd using the provided lift and drag data
  • Learn about integrating acceleration terms in projectile motion
  • Research the effects of varying angles of attack on drag and lift
  • Explore numerical methods for solving differential equations in motion analysis
Aerospace engineers, physics students, and anyone involved in fluid dynamics or projectile motion analysis will benefit from this discussion.
Simms16
I obtained lift and drag forces for an object I was testing in a wind tunnel and I wanted to know if it was possible to do a projectile motion problem with the following variables;
I know the initial velocity of the object, V=76m/s, the possible launch angles = 30, 45, or 60 degrees, and gravity = 9.81m/s^2.
-I also have tabulated data of the lift and drag forces on the object at 3 different wind speeds (80, 130, 170 mph) while varying the angle of attack (AOA) from -10 to 30 degrees.
I took the three drag values at 0 degrees AOA and found a linear relationship between the wind speed and drag values. I used that relationship and subtracted drag off of the ideal equations of distance and height of projectile motion and the values I got don't make sense. Is there another way I can do this or am I missing some important information to solve this problem
Ideal case#
Ax = 0
Ay = -g
Practical Case#
Ax = -Drag/mass
Drag = -Cd.(Area.rho.V^2)/2
Ay = -g + lift/mass
Lift = -Cl.(Area.rho.V^2)/2
You have the data, calculate Cl & Cd at the data points, interpolate to get Cl & Cd in terms of V, integrate twice the acceleration term to get the distance.
Note: The actual & calculated value still won't match. Can you guess why?
  • · Replies 16 ·
21K
  • · Replies 30 ·
