Phase portrait of nonlinear system of differential equations
The phase portrait of the nonlinear system defined by the differential equations x' = x^2 and y' = y^2 features an equilibrium point at (0,0). The associated linearized system is represented by x' = 0 and y' = 0, indicating lines of equilibria along x = 0 and y = 0. Solutions to the nonlinear system are given by x(t) = -1/(t + C1) and y(t) = -1/(t + C2), with trajectories approaching the origin along the line y = x for specific initial conditions. All trajectories are straight lines directed towards the origin, confirming the stability of the equilibrium point.
  • Understanding of nonlinear differential equations
  • Familiarity with phase portraits and equilibrium points
  • Knowledge of linearization techniques in dynamical systems
  • Ability to solve separable differential equations
  • Study the concept of stability in nonlinear systems
  • Learn about the Lyapunov method for analyzing equilibrium points
  • Explore phase plane analysis for higher-dimensional systems
  • Investigate the role of initial conditions in determining trajectories
Students and researchers in mathematics, particularly those focusing on dynamical systems, nonlinear differential equations, and phase portrait analysis.
p3forlife
Describe the phase portrait of the nonlinear system x' = x^2, y' = y^2
Also, find the equilibrium points and describe the behaviour of the associated linearized system.
We have an equilibrium point at (0,0).
The associated linearized system is x' = 0, y' = 0. The phase portrait for this consists of lines of equilibria along x = 0, and y = 0.
For the nonlinear system, I have found solutions x(t) = -1/t and y(t) = -1/t. I don't know what these solutions mean in terms of a phase portrait. Nor can I express the solutions in terms of constants x_0 and y_0.
It looks like you have left off the constant of integration when you found solutions x(t) and y(t). Both of your differential equations are separable.
dx/dt = x2 ==> dx/x2 = dt ==> [itex]\int dx/x^2 = \int dt[/itex]
==> -1/x = t + C1 ==> x = -1/(t + C1)
Similarly, y = -1/(t + C2)
You should be able to determine the constant from your initial conditions.
In the special case where C1 = C2 = 0, the trajectories follow the line y = x. If t > 0, the solution points approach the origin along the part of the line in the third quadrant. If t < 0, the solution points approach the origin along the part of the line in the first quadrant. Different initial conditions will generate different trajectories, but I believe all of them will be straight lines pointing into the origin.
Does that make sense? It has been a lot of years since I studied dynamical systems, so I might be a little off base on some of this.
Thanks :) It makes sense.
  • · Replies 27 ·
