1kg object and I apply a force of 1N for 1sec, It will move 1/2m
  • Context: Undergrad
  • Thread starter Thread starter Mentallic
    Apply Force
The discussion revolves around the concept of work in physics, particularly in relation to applying a force to a moving object versus a stationary one. Participants explore the implications of force, motion, and energy transfer, examining how these factors interact in different scenarios. The conversation includes theoretical considerations and mathematical reasoning.
  • One participant questions how a 1N force applied for 1 second results in a 0.5m displacement for a stationary 1kg object, suggesting confusion over the calculation of work.
  • Another participant asserts that work is a vector and emphasizes that the total work done includes contributions from both the applied force and the object's existing motion.
  • A participant clarifies their calculation of displacement using the equation s=ut+1/2at², asserting that the acceleration due to the applied force is 1 m/s².
  • There is a discussion about the nature of work being scalar, with one participant referencing a source that defines mechanical work as energy transferred by a force acting through a distance.
  • One participant acknowledges a misunderstanding regarding the vector nature of work and force.
  • Another participant distinguishes between work and power, noting that the work equation does not include a time element, while power is defined as work done per unit of time.
  • A participant discusses kinetic energy, stating that the object at 10m/s has an initial kinetic energy that changes when a force is applied, leading to a calculation of work as the change in kinetic energy.
Participants express differing views on the nature of work, the role of force in motion, and the relationship between work and kinetic energy. There is no consensus on these points, and the discussion remains unresolved.
Participants operate under various assumptions, such as the absence of resistive forces and the definitions of work and power. The discussion includes unresolved mathematical steps and differing interpretations of physical concepts.
Mentallic
Homework Helper
I'm having trouble understanding work.
Taking an example: If I have a 1kg object and I apply a force of 1N for 1sec, It will move 1/2m and thusI will have done 1/2 (units?) of work, by the equation W=Fs.
But instead, if I consider the same object now traveling at 10m/s and apply a 1N force for 1 sec, the object will travel 10.5m in that time, so now the work done is 10.5?
I don't understand how you can do more work when all you've done is apply the same force to the same object for the same amount of time, but the only difference is that the object in the first case was stationary relative to you, while the other case it was moving. And also, if I applied the force in the direction opposing the motion, less work would have been done than if I applied it in the direction of motion?
first of all, how did you work out that the object will only move 0.5m if you apply a 1N force for 1 second to it?
Work is a vector as is force. The work is done by the force in the direction of the force. If an object is already traveling at 10 m/s, the work that you do by applying your 1N for 1 second is the same as in the first example. The force that is causing the object to travel at 10m/s is also doing work of it's own. The work of both together is the total work. Work is just energy and is expressed in Joules [J] usually as this is the SI unit or work and energy.
What's really going to blow your mind is that if you push the object one direction with 1N for 1 second and then push it in the opposite direction with 1N for 1sec and it returns to it's original position, you've done no work. That's the beauty of vectors.
By using [itex]s=ut+1/2at^2[/itex]
[itex]a=F/m[/itex] so therefore a=1 and t=1, u=0.
But there is no force required for the object to move at 10m/s. I'm assuming a non-resistive environment so it will continue at it's usual velocity.
What? From http://en.wikipedia.org/wiki/Work_(physics ) :
mechanical work is the amount of energy transferred by a force acting through a distance. Like energy, it is a scalar quantity,
:redface: indeed, my bad.
I think that you are confusing work and power, in the equation for work (force X distance moved) there is no time element, power is work done per unit of time.
So the object will have an initital kinetic energy of 1/2mv², so (1/2(m)(10)²) and then you will be increasing that kinetic energy to 1/2m(10.5)² by adding your force in the same direction of the motion and work is the change in kinetic energy. So, W = E2-E1 or 1/2m(10.5²-10²)
  • · Replies 67 ·
  • · Replies 54 ·
  • · Replies 41 ·
