F: [0,infinity) -> R is continuous at every point of its domain
The discussion centers on proving that if a function f: [0,infinity) -> R is continuous at every point in its domain and uniformly continuous on the interval [b,infinity) for some b>0, then f is uniformly continuous on the entire interval [0,infinity). Key insights include leveraging the continuity of f on the compact interval [0,b] to establish uniform continuity. The Heine-Borel theorem is referenced, confirming that closed and bounded sets are compact, which simplifies the proof process.
  • Understanding of continuity and uniform continuity in real analysis
  • Familiarity with the Heine-Borel theorem regarding compact sets
  • Knowledge of sequences and their convergence properties
  • Basic concepts of proof techniques, including proof by contradiction
  • Study the Heine-Borel theorem and its implications for compactness in real analysis
  • Learn about uniform continuity and its definitions in various contexts
  • Explore proof techniques in real analysis, particularly proof by contradiction
  • Investigate the relationship between continuity on closed intervals and uniform continuity
Students and professionals in mathematics, particularly those studying real analysis, as well as educators looking for insights into teaching continuity and uniform continuity concepts.
whitey06
Problem:
Assume that f: [0,infinity) -> R is continuous at every point of its domain. Show that if there exists a b>0 so that f is uniformly continuous on the set [b,infinity) then f is uniformly continuous on [0,infinity).
I don't really know where to start with this one, any help would be greatly appreciated
The main point would be to prove that if f is continuous on [0,b], it will be uniformly continuous on that interval, and therefore on [0,∞).
whitey06 said:
Problem:
Like suggested by mathman, since f is continuous on [0,infinity) by the hypothesis, and since for some b>0 f is uniformly continuous on the set [b,infinity), again by the hypothesis of the problem, then to show that f is uniformly continuous on [o,infinity) all you need to do is to show that the continuity of f on [0,b] implies the uniform continuity of f on that interval. Actually there is a more general theorem of this. Namely, if f:A->R is a continuous function on A, with A compact, then f is uniformly continuous on A. Have you proved such theorem during your course? if yes, use it, if not then prove it. Note, this same theorem can be proved by exploiting the compactness concept, and without using it. So, if you don't know what compact means, then there is a way around it. But compactness in this case makes things easier, since we know that every closed and bounded set is a compact set (heine-borel theorem), so for your problem that would mean that [0,b] is a compact set as well.
Like said, if you haven't learned compactness,then you can prove it by contradiction. that is, start by assuming that even though f is continuous on (lets take a more general case) [a,b], it is not uniformly continuous on [a,b]. What does this mean in terms of the definition of uniform continuity?? Try to generate two sequences a_n and b_n, such that |a_n-b_n|<d, implies |f(a_n)-f(b_n)|>=e, and come to a contradiction somewhere along those lines.
This theorem, (without using the notion of compactness, was part of one of my projects for HOnors Real Analysis, so if interested, let me know, i can email the whole project to you). But try it first on your own.
Cheers!
  • · Replies 22 ·
  • · Replies 18 ·
