How is the freezer part of a refrigerator is more cooler than the other parts?
The freezer compartment of a refrigerator operates at a lower temperature than the fridge due to the refrigeration cycle, which involves the compression and expansion of a refrigerant. The refrigerant is compressed, cooled, and then throttled through an expansion valve, resulting in a significant temperature drop. In combined fridge-freezer systems, two throttles are utilized—one for the fridge and another for the freezer—allowing for distinct temperature control. This design ensures that the freezer maintains a colder environment necessary for preserving frozen foods.
  • Understanding of the refrigeration cycle
  • Familiarity with refrigerants and their properties
  • Knowledge of thermodynamics related to gas expansion and compression
  • Basic principles of heat transfer in appliances
  • Research the properties and types of refrigerants used in modern refrigerators
  • Learn about the design and function of expansion valves in refrigeration systems
  • Explore thermodynamic principles related to heat transfer in refrigeration
  • Investigate the differences between various refrigerator designs, including single and dual compressor systems
Appliance engineers, HVAC technicians, and anyone interested in understanding refrigeration technology and its applications in household appliances.
pras_quantum
please explain me..
Science news on Phys.org
Both freezers and fridges work on a 'refrigeration cycle' http://en.wikipedia.org/wiki/Refrigeration_cycle.
A working fluid (refrigirant) vapour is compressed so it heats up, it then passes through an condenser to cool it down to a liquid. This is then throttled, it's pressure is lowered, which drops the temperature. It's then passed through the fridge to cool the air inside.
The key to why a freezer is colder than a refrigirator is that the working fluid is throttled through an expansion valve to a lower temperature.
http://www.howstuffworks.com/refrigerator4.htm
A summary. The fuild inside the fridge freezer plumbing cools when expanded. In the freezer it is expanded more to allow it to drop to a lower temperature.
In combined fridge freezers that run off 1 system. Two throttles are used, one that goes to the fridge and the other goes to the freeezer.
  • · Replies 32 ·
  • · Replies 29 ·
  • · Replies 42 ·
